recommended cam break in - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2008, 08:03 PM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default recommended cam break in
i always ran them at 2500 rpm for 5 min am i wrong?
Old September 13th, 2008, 08:11 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Proper Procedure
As soon as the engine fires, bring the rpm up to 2000 to 2500 during the first 30 minutes of
operation. Slower engine speeds will not supply the camshaft with an adequate amount of oil for
the break-in period. The engine rpm may be varied periodically from 2000 to 2500 to direct oil
splash to different areas of the camshaft. After the 30 minute break-in period, change the oil and
filter again to be sure all contaminants and break-in lube are removed from the engine. The inner
valve springs should now be replaced and the correct rocker arms installed. http://compcams.com/Base/pdf/FlatTap...chBulletin.pdf
Old September 13th, 2008, 08:14 PM   #3
unclebeaner
im using a roller cam not flat tappet
Old September 13th, 2008, 09:10 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
no break in required then.
Old September 13th, 2008, 09:39 PM   #5
unclebeaner
o rly?
Old September 13th, 2008, 10:03 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yea. only flat tappet cams need breaking in. only reason is because the only lubrication the lifters have is slung off the crank. they need to wear in properly
Page generated in 0.16105 seconds with 41 queries
