SFA Sonoma Steering box - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 12th, 2008, 09:33 PM   #1
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Default SFA Sonoma Steering box
I have not been able to locate just a dropped pitman arm for my truck around town so I am looking into just swapping steering boxes.
Is there another steering box that would work with my S10 style steering shaft that might have about a 4" drop pitman arm?
Grunto is offline   Reply With Quote
Old September 12th, 2008, 10:17 PM   #2
sonoma944
HOTROD
sonoma944's Avatar
I used a 2wd pitman arm on mine and it seems fine, i have a dana 44 with jeep waganeer leaf springs and a high stear arm coming off the top knuckle of the passenger side.
sonoma944 is offline   Reply With Quote
Old September 12th, 2008, 10:25 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
use a jeep cherokee pitman arm.. will bolt right onto your Sonoma's Steering box and give you roughly 4" of drop
Old September 12th, 2008, 10:31 PM   #4
Grunto
Grunto's Avatar
How much of a drop is the 2wd arm?
Edited out last question, I need to read better.
Old September 28th, 2008, 10:05 PM   #5
Grunto
Grunto's Avatar
Alright, so I got a pitman arm for my truck, but now I got a situation...
The factory pitman arm dropped behind the steering box, but with the steering setup for my axle, I need it to drop to the front of the box.
If I just throw the pitman arm on there so that it is facing forwards, that will make me steer the opposite directions, correct?
Is that the reason many people use an Astro box? Is there a certain year I should get one from?
Old September 28th, 2008, 10:07 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
92 2wd ASTRO Van box..
and yes if u run the current set up you'll just turn the wheel right to go left kinda thing..
Old September 28th, 2008, 10:10 PM   #7
Grunto
Grunto's Avatar
It almost sounds tempting to play around the yard with...
Thanks, any idea how much I should be willing to spend for one at the junkyard? The same pitman arm works?
Old October 5th, 2008, 10:43 PM   #8
Cartman
Can't lose with 42s
Cartman's Avatar
If you are looking for a yard with some astros I'd goto Erickson's salvage here in the burg. Hes real fair!
I try to avoid Genes and all the other places in TC like the plague..Swains or Ericksons always have what I'm looking for and there prices are always fair.
Cartman is offline   Reply With Quote
Page generated in 0.27988 seconds with 47 queries
