More Mayhem and Chaos then Nuzzy's (badder then Stans too) FJ40 v2.0 pg17 updates - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 18th, 2008, 12:02 PM   #41
Chop
Mischievous Badger
Chop's Avatar
Originally Posted by Bones View Post
good choice on joints... I would not build a rig with heims again
why?
brimy:
with rubber mounted uppers like that. to locate your axle cented in the vehicle. arnt you worried about the bushing flex causing your axle to move more side to side when you turn or when you side load your suspension.
Old September 18th, 2008, 12:12 PM   #42
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Originally Posted by Chop View Post
brimy:
I am going full hydro, so I won't be putting that side load from steering on it. I am not really considered with a little bit of movement as I won't be driving it on the road. If I was going to drive it on the road, I would probably use plastic bushings. I have run all poly bushings in my rear suspension for a LONG time and have had really good luck with longevity and have not had any issues.
JcrOffroad.com
Like us on Faceook!
Old September 18th, 2008, 07:19 PM   #43
brimy311
brimy311's Avatar
Updates!
Rear Frame before:
Rear after:
Capped:
Cut off the sliders and cleaned up the prepped the frame for the boat sides:
JcrOffroad.com
Like us on Faceook!
Old September 18th, 2008, 07:41 PM   #44
Chop
Mischievous Badger
Chop's Avatar
Oh your not driving it on the road. you will like the full hydro i have it on my jeep. and love every second i did 1.25" Heim joints upper and lower front and rear. im looking forward to seeing the rest of your build.
Old September 18th, 2008, 10:02 PM   #45
I'm doing the same on my CJ, JJs at the axle end, poly bushings at the frame, dual triangulated, seems a lot run this with no issue, and like the cushioning.
Any plans to gusset the knuckle balls since you have a factory housing? They seem to like to bend right between where your shock mount is and the ball, where the tube gets thin on the I.D.
Old September 19th, 2008, 09:31 AM   #46
ShoNuff82
Im running the same thing on mine but with the bushings at the axle end and jj at the frame just to keep the jj out of the water as much as possible.
seems to work great. I'd never go back to heims.
ShoNuff82 is offline   Reply With Quote
Old September 20th, 2008, 12:08 PM   #47
brimy311
brimy311's Avatar
Started working on the Boat Sides, just finished up the Dside. Thye are going to be skinned with 1/2" UHMW eventually.
I used 1 3/4 x .188 tube for the rockers/boatsides. Here is what the thickness looks like! BEEFY!
JcrOffroad.com
Like us on Faceook!
Old September 20th, 2008, 12:31 PM   #48
Bones
Bones's Avatar
why?
they pop under loading/unloading and I swear it is as loud as an axleshaft snapping. It only happens once or twice a day of wheeling and I'm starting to get used to it, but its not even like they are severly whipped out or anything. They are QA1s, so they're not junk
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 21st, 2008, 01:26 PM   #49
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
Originally Posted by Skooter_Built View Post
You do more work in a day then i do in 2 weeks, you have skills
shop tools and facilities help.
nucken futs brimy. keep it up!
muddy maki is offline   Reply With Quote
Old September 21st, 2008, 06:48 PM   #50
brimy311
brimy311's Avatar
Bending tube is not my forte, so MonkeyEvil is going to be doing all the kick@ss tube work on this thing. He is absolutly AMAZING at creative tube work! He has a pretty bad@ss idea for the top half, which will be built tomarrow. The middle section of the cage so far is 1 piece, bent from 199" of tube and has 8 bends in it.
Here is what it took to finish up the bends:
Test fit driver:
For the fun of it, we test fit a YJ bench:
Rest to come tomorrow!
JcrOffroad.com
Like us on Faceook!
Old September 21st, 2008, 07:17 PM   #51
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Nice. I can imagine that many compound bends one piece gets pretty nerve racking near the end
Is that jack stand in the front holding up your battery
Nuzzy is offline   Reply With Quote
Old September 21st, 2008, 07:21 PM   #52
brimy311
brimy311's Avatar
Yep! The weight of the battery was pulling the cowl down. It will be there until I can get the caged tied into the cowl.
JcrOffroad.com
Like us on Faceook!
Old September 21st, 2008, 07:43 PM   #53
badazzamc
Get Some
badazzamc's Avatar
looks good
Old September 21st, 2008, 08:08 PM   #54
KartRacer
Blowd up
KartRacer's Avatar
That is badass. I can't imagine doing that many bends in one piece.
Old September 21st, 2008, 08:41 PM   #55
95geo
newbie
95geo's Avatar
smart move with the heavier wall in high impact places.... I'll be doing the same.
Old September 22nd, 2008, 12:00 AM   #56
Stan
I got a gold chain
Stan's Avatar
My Seats!!!!!!!!!!!
Can wait to sniff test them.
Stan is offline   Reply With Quote
Old September 22nd, 2008, 12:21 PM   #57
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
...MonkeyEvil is going to be doing all the kick@ss tube work on this thing. He is absolutly AMAZING at creative tube work!
I agree. His "tube" work is the stuff of legends.
@clarkstoncracker
Old September 22nd, 2008, 12:41 PM   #58
brimy311
brimy311's Avatar
Door Bars:
Rear Tailgate bars:
Top view, Big Props to Daryl for the awesome tube work:
JcrOffroad.com
Like us on Faceook!
Old September 22nd, 2008, 12:47 PM   #59
KartRacer
Blowd up
KartRacer's Avatar
Damn. Lookin good.
Worlds fastest buggy conversion?
Old September 22nd, 2008, 12:59 PM   #60
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
thanks and
JcrOffroad
Zoom Zoom!
Page generated in 0.55923 seconds with 83 queries
