Oil fitler adapters - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2008, 12:12 PM   #1
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Default Oil fitler adapters
I have an old style 4-bolt chevy small block.
I want to run a spin on filter. I have tried 2 Mr Gasket adapters seen here:
http://store.summitracing.com/partde...5&autoview=sku
I can not get the gaskets to seat properly as it is leaking past the seal.
Does anyone have any suggestions or ideas as to something of a higher quality that I can run that will seal a little bit better? I am not sure why this stupid thing keeps leaking. I have put 3 o-rings in it and I am on the second adapter itself... this is stupid.
Old September 11th, 2008, 12:13 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
I think you left out that you said your system is making 80 psi at idle.
Old September 11th, 2008, 12:22 PM   #3
Hacksaw
Hacksaw's Avatar
My motor is making 80 PSI at idle, the pressure should drop as the motor gets more broke-in
Old September 11th, 2008, 12:34 PM   #4
s.hembree
s.hembree's Avatar
Use a Transdapt #1024... it has an actual shoulder to hold the seal. You have to run a Ford style filter though...
Old September 11th, 2008, 12:39 PM   #5
bearlys2005
bearlys2005's Avatar
Good luck... I had a SB 327 that ran 50# at idle warmed up and could never get that thing to seal... The filter adaper leaked as well as the rear main. The old blocks always leak it is just part of the engine. I updated to an LT1 and all the modern seals and it doesn't leak a bit...
bearlys2005 is offline   Reply With Quote
Old September 11th, 2008, 12:41 PM   #6
clarkstoncracker
lol
x2..
I had an oil cooler on the first 350 in my jeep and I couldn't get it to seal @45psi at idle. It would leak bad under high RPMs/70-80 PSI. I ended up removing the oil cooler.
Old September 11th, 2008, 01:05 PM   #7
Hacksaw
Hacksaw's Avatar
Thanks, that looks a little bit higher quailty
Um, there are thousands of theese motors running around, i know MANY people that have theese motors that dont have this problem
Old September 12th, 2008, 12:07 AM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
stupid question but are you running the right filter? i switched to a fram hp1(?) basically a tall 350 filter with a better longer thread section and a seal that cannot be blowen out just my .02
Old September 12th, 2008, 09:30 AM   #9
Hacksaw
Hacksaw's Avatar
It's not breaking the seal of the oil filter. It is blowing out the seal of the adapter to the block.
Old September 12th, 2008, 11:01 PM   #10
unclebeaner
ahhhhh i see
Page generated in 0.27007 seconds with 53 queries
