What vehicles have m50d's? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2008, 02:35 AM   #1
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Default What vehicles have m50d's?
I asked this over on the bii forum but I'm pretty sure it will get better visibility here.
Anyway,
I'm looking to swap my pos fm-145 for an m50d and would like to know what vehicles to look at when I go to the pull a part. I'm just not sure if it was strictly rangers or what. Also, what other parts should I grab with the trans to complete the swap?
Thanks,
Bryce
artistic_gore is offline   Reply With Quote
Old September 11th, 2008, 02:45 AM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
F150's and maybe some 250's have a M50D-R2 Rangers will have the M50D-R1, though in 2 versions yet again. The M50D-R2 has an integral cast bellhousing that fits the 289/302/351W/300-I6/240-I6/250-I6 series engines, so unless you're swapping one of those in, it may be a little difficult to make 'er work.
Ranger wise (M50D-R1):
2.3L and the 3.0L should be the same and interchange without issue. Same ratios.
The 4.0L is different and will interchange with at least the 2.9L (please recheck and verify that), little higher ratios, but not a whole lot. Same O/D gear though.
Those are the bolt in, direct swaps that I can remember off the top of my head.
4x4? - All Ranger T-cases should bolt up to the end of the adapter housing, though you may have to fiddle with the linkages.
What engine do you have and what year?
Old September 11th, 2008, 05:48 AM   #3
04PSD
aka Langford
04PSD's Avatar
The 97+ F-150's came with two different model M50D's, Captain Ledd knows a whole lot more about them than I do though.
The 4.2 V6 F-150's came with the same one that they used in the older trucks and will bolt up to 300, 302, 351, etc. But they also put the trans in the 97+ F-150's that came with the 4.6 V8, but it will only bolt up to the 4.6/5.4 because of the cast bellhousing so there is no way to interchange them.
I didn't realize this when I bought a new motor for my F-150 (v6 to v8 swap), and I ended up having a motor that wouldnt bolt to my transmission.
04PSD is offline   Reply With Quote
Old September 11th, 2008, 06:29 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
They also came in the Explorers, Mazda B series, and the mazda navajo
Old September 11th, 2008, 07:02 AM   #5
i've also found the M5ord-1's in 89-90 B2's, but not every time
Old September 11th, 2008, 12:05 PM   #6
artistic_gore
I own @ halo
Mine is an 89 BII with the 2.9. I'll check the trans code today to confirm what's in there already. I thought it was an fm-145 but I could be mistaken.
Thanks for the info. It's nice to know that I can scope out more than just bii's and rangers for the trans.
Old September 11th, 2008, 03:07 PM   #7
artistic_gore
I own @ halo
I double checked and it is an FM-145 or 146. I didn't check the trans code so I'm not sure which.
Anyway, I've done a little reading and I'm curious if there was a 4.0L ranger. I read somewhere that you can take the 4.0L flywheel, starter, and clutch set to give a better clutch on the BII. I think I'd like to do that if I'm in there already. That and I could get the trans and flywheel from the same truck.
Thanks,
Bryce
Edit: never mind, you said that explorer's have the M50d-r1 so I think that's where I'll focus my attention.
Old September 11th, 2008, 05:37 PM   #8
Captain Ledd
Ranger Addiction?
Thanks,
Bryce
In case you run across one, yes, Rangers came with 4.0's and M50D-R1's.
3.72 / 2.20 / 1.50 / 1.00 / 0.79 (2.3L / 3.0L)
3.40 / 2.05 / 1.31 / 1.00 / 0.79 (4.0L)
Ratios are the same between Ranger's and Explorer's
Old September 11th, 2008, 09:03 PM   #9
And Yes you can take a 4.0L flywheel, and clutch assm and use it on the 2.9L
The 4.0L clutch is much larger and works much better then the 2.9L clutch
Old September 29th, 2008, 05:44 PM   #10
Rulebreaker
Cadillac Jeeper/ RPM
Rulebreaker's Avatar
I'm guessing your B2 has a FM146 and if it does you can bolt a M50D in easy. If it has the FM145 (I doubt it) you will be doing some drive line changes to put in the M50D. The FM145 is shorter than the FM146, and M50D. FWIW 2.8,2.9, and 4.0L engines share the same bolt pattern. RB
Rulebreaker is offline   Reply With Quote
Page generated in 0.51615 seconds with 53 queries
