Welder recommendations - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2008, 05:37 PM   #1
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Default Welder recommendations
I would like some info from you guys (the fabricators) on a purchasing a welder. I have started to look into them little knowing that soon I will be buying one for the garage for the Jeep. I am thinking a mig welder and I have 220V already run to my garage. Give me some recomendations of welders and things to look for when buying.
Chris
Old September 10th, 2008, 08:36 PM   #2
swi dog
yeah, its a barbie jeep
swi dog's Avatar
i have a hobart 187 mig with gas i bought it at tractor supply it is user frendly and will weld everything you need to weld i believe it was around $700 its alot of money but worth it
swi dog is offline   Reply With Quote
Old September 10th, 2008, 08:53 PM   #3
Tab
Tab's Avatar
pick a color (red or blue) and get the biggest one you can afford. You'll be happy with either.
Old September 10th, 2008, 09:23 PM   #4
jeeperbrian
GLFWDA member
i personnally like the miller migs, if you want a stick i'd go lincoln.
Old September 10th, 2008, 09:48 PM   #5
Blackjackbender
hobart 175-187 if you are on a budget
Old September 14th, 2008, 05:02 PM   #6
jsmtam90
Old School Jeeper Club
jsmtam90's Avatar
imo-since you already have 220v power to garage the
lincoln power mig 180c mig welder is a nice unit.
jsmtam90 is offline   Reply With Quote
Old September 14th, 2008, 05:32 PM   #7
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
x3.14
Jesse-James is offline   Reply With Quote
Old September 14th, 2008, 05:49 PM   #8
Yota Bill
I have a Hobart 140 (yes, its a 20A 110 machine) that I bought before I bought the new house, and didnt have 220 available in the old place (wasnt going through the work of adding it in a rental)..I like the welder, it has always worked good, and I dont have a problem welding up to 1/4" or 3/8" material...of course, I take the extra time to gouge and run multiple passes alot of the time, and have to pay attention to the duty cycle, but I have ran it well past its rated duty cycle without any problems...
I do intend on getting a better 220 machine, and it will also be a Hobart (unless I find a good deal on something else), but I'll still keep this one around, possible set it up to run just aluminum (I never do any big structural aluminum stuff anyway, and I hate spool guns)
for the money, Hobart machines are the way to go...
Old September 14th, 2008, 06:36 PM   #9
ksejeeper
Money pit
ksejeeper's Avatar
Send a message via Yahoo to ksejeeper
I have the hobart 187, and like it vary much. its made by miller so finding parts for it will be easy. welding with it is vary easy, and it lays a nice bead of weld. I got mine from northern tool for like 650 with free shipping.
2012 Can-Am commander 1000 X
2014 Ram 3500 Meg Cab 4x4 6.4 Hemi Blacked out edition.
ksejeeper is offline   Reply With Quote
Old September 14th, 2008, 06:51 PM   #10
300Grand
300Grand's Avatar
X3 on the Hobart 187, great welder! It's basicly a Miller in drag. The gun even says Miller.
300Grand is offline   Reply With Quote
Old October 18th, 2008, 10:05 AM   #11
Jasper_Jpr
Northwest Ohio Crawlers
Jasper_Jpr's Avatar
I have the model prior to the Hobart 187 mine is the 180. They also now have a 210 suitcase model if you think you need the extra amperage Our Miller rep at work told me they come down the same line as the Miller they just put the grey or blue cover on depending which one they need to fill orders. I love it and use it more than my big setup. (Big set up is a Ranger GXT gen/weld with a LN25 wire feeder attachment) It has the small gun witch makes tight areas easier to get to. Usually about now Tractor Supply will have them in a special kit for Christmas. Mine was one of these kits. These kits will have a cart a small gas bottle auto darkening helmet a couple spools of wire and spare consumables and I think gloves. My kit was like $50/$75 more than just the welder well worth the extra $$ for the kit
Jasper_Jpr is offline   Reply With Quote
Old October 18th, 2008, 10:11 AM   #12
Jasper_Jpr
Jasper_Jpr's Avatar
Found this it may help
http://www.lincolnelectric.com/knowl...wirefeeder.asp
This is a nice book also
https://ssl.lincolnelectric.com/linc...prodnum=C4.200
Name brand links
http://www.hobartwelders.com/
http://www.millerwelds.com/
Old October 18th, 2008, 10:24 AM   #13
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Buy the biggest machine you can afford and if you have to, buy used!
JcrOffroad.com
Like us on Faceook!
Old October 18th, 2008, 10:34 AM   #14
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Same reason I bought the Miller DVI, only had 110v but knew I was going to have 220v someday. Has welded everything I have needed to.
Old October 18th, 2008, 03:37 PM   #15
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Buy the one brimy is selling in Misc for sale section.
Nuzzy is offline   Reply With Quote
Old October 18th, 2008, 06:35 PM   #16
cruiserjg
dodge man
cruiserjg's Avatar
X2
cruiserjg is offline   Reply With Quote
Old October 19th, 2008, 04:04 AM   #17
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Doesn't Miller make a machine that is 220v or 110v?? I think Miller or Lincoln does. Hobart uses Miller Tough Guns for leads or Rough Necks. I've used both and I like the Bernard Centerfire gun over them.
Old October 19th, 2008, 04:18 AM   #18
boggin-machine
boggin-machine's Avatar
yes its the miller dvi2 good machine. buddy has one and as stated so does 99tj. i almost bought one myself. im gonna hold out for a bit longer.
Old October 19th, 2008, 08:23 AM   #19
X2, I have the same one and love it. I like his price better than mine too
Page generated in 0.31568 seconds with 80 queries
