hollow ball mount, or solid? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2008, 09:21 AM   #1
SuperYooper
Thread killer
SuperYooper's Avatar
Default hollow ball mount, or solid?
What are you using for your tow rig? My hollow ball mount says it is only rated to 6,000 pounds with a tongue weight capacity of 500 pounds. The solid mounts are rated for 10K and something like 1200 lbs tongue weight.
I have a 2,000 pound car hauler and will be hauling a YJ or TJ with it... should I buy a solid ball mount? I have talked to a couple of people with mixed replies... I don't have a problem spending the money, but it costs around $40 and if I don't need it I don't want to throw the money away.
I just bought the truck and trailer so I'm new to towing, looking for some input from experienced haulers.
SuperYooper is offline   Reply With Quote
Old September 10th, 2008, 10:41 AM   #2
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i always run a soild mount
Old September 10th, 2008, 10:51 AM   #3
Bones
Bones's Avatar
are you talking about the ball itself or the reciever that slides into the hitch?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 10th, 2008, 10:56 AM   #4
CreativeFab
used to be Ironman
CreativeFab's Avatar
If your trailer weighs 2000 pounds and your Jeep weighs 4000 pounds your @ the rated capacity now. Add your camping gear or tools and you will exceed the draw bar rating.
Mind you they under rate them but play it safe and go for the solid draw bar. I sell several brands and the Draw Tite brand I carry is rated for 12,000 tow and 1,200 pound tongue and sells for $39.00.
Pat
Old September 10th, 2008, 11:26 AM   #5
Thousands of dollars in the tow rig.
Thousands of dollars in the trail rig.
Hundreds of dollars in the trailer.
Family on board............................. priceless.
For the few dollars more go with the better setup.
Old September 10th, 2008, 11:54 AM   #6
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Solid. And the largest shank diameter I could find for the ball.
Nuzzy is offline   Reply With Quote
Old September 10th, 2008, 11:58 AM   #7
junk90xj
ALLPRO AUTO
junk90xj's Avatar
i agree with all the above but i use a hollow one with no issues.
http://www.apalansing.com/
Old September 10th, 2008, 12:29 PM   #8
Sandals
Fucking Zen as Shit
Sandals's Avatar
Mine is all solid now with my heavy ass weight distributing hitch
Old September 10th, 2008, 12:39 PM   #9
SuperYooper
Thread killer
Thanks for the replies; I'm going to pick up a solid one. Ironman, I wish you were local to me - but TSC has 'em and I need it for Friday.
I picked up a nice brake controller, 4 10K tie-down ratchets, and got it registered yesterday. Just need to wire up the controller, pick up the solid ball mount (I have the big-shank ball already), adjust the brakes, lengthen/replace the safety chains, and I think I'm good to go!
Old September 15th, 2008, 10:26 AM   #10
SuperYooper
Thread killer
I picked up the solid ball mount and had peace of mind towing my junk all the way to Michigamme this past weekend.
Old September 17th, 2008, 07:54 PM   #11
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
also watch what ball you buy alot of the cheap ones will barely haul the weight of your trailer. for recievers i get either double wall or solid
Old September 23rd, 2008, 12:38 PM   #12
SuperYooper
Thread killer
I think both of the ones that I bought are "Master Lock" brand, and have the bigger shank (like 1"-ish).
Old October 15th, 2008, 10:13 PM   #13
Jrod-13
poser wheeler
better yet, go to walmart, and spend $40 on a triball, that way you can hook up to anything.. and they are a solid hitch..
Jrod-13 is offline   Reply With Quote
Old October 16th, 2008, 09:39 PM   #14
Mclovin
"The Situation"
Mclovin's Avatar
Pintle
Old October 16th, 2008, 09:39 PM   #15
Mclovin
"The Situation"
Mclovin's Avatar
I run a 2 1/2" drop how do i get a tri ball set up like that ?
Old November 12th, 2008, 10:18 AM   #16
Fraser
Fraser's Avatar
just have two separate hitches w/ the balls on them. so you dont have to chage balls, etc. tri-balls look teh goofy, dunno how good they are tho
Old November 12th, 2008, 10:58 AM   #17
PavementPounder
PavementPounder's Avatar
Have two solids with large shanks. Have used a hollow one only to get out and see it bent down a few degrees at the end of the tow.
No more hollow.
Page generated in 0.26731 seconds with 74 queries
