wiriing diagrams - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2008, 01:38 PM   #1
masterbeatty
masterbeatty's Avatar
Default wiriing diagrams
where can i find a wiriing diagram for a ford f150 77. i went to get a manual and noone had one. i need the wiriing for the lights.
Old September 9th, 2008, 06:06 PM   #2
lil monster
BUILT NOT BOUGHT
lil monster's Avatar
Send a message via Yahoo to lil monster
What's wrong with the lights? Wirin is very simple in those years. Start with checking the high beam switch on the floor, then the switch for the lights, the old switches have very primative contact points, and the high beam switches rust out. If you have brake light trouble, don't forget about the brake switch on the brake pedal. The spring and contacts rust out too.
lil monster is offline   Reply With Quote
Old September 10th, 2008, 09:04 AM   #3
masterbeatty
o the problem is the hack that owned it before me. the fuel sending unit wont register. so i replaced some grounds. but the guy seriously hacked it together. he has wires cut and sodered and just taped. the brake light switch is aftermarket. when i it my breaks my front right marker light comes on. i want to re wire all the lights
Old September 10th, 2008, 10:03 AM   #4
lil monster
BUILT NOT BOUGHT
The wiring for the lighting is the same Until the early 80s, so even if you find a manual for those years it will still work. If you were closer to me, I'd let you use mine.
Old September 10th, 2008, 09:45 PM   #5
masterbeatty
ok that works. yea i started into it because i figured it cant be hard and then i find wires soldered together and then taped and some wernt even taped the were just hanging down. i think maby this weekend ill go buy a manual.
Old September 11th, 2008, 10:41 AM   #6
lil monster
BUILT NOT BOUGHT
Good luck!
Old September 11th, 2008, 06:51 PM   #7
masterbeatty
im guna need all i can get
Old September 11th, 2008, 07:50 PM   #8
lil monster
BUILT NOT BOUGHT
Jus match the colors hehehe
Page generated in 0.18239 seconds with 47 queries
