Set 13-14 Mud Drags & Bogg. Momsmotorsports.com - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old September 9th, 2008, 12:18 PM   #1
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
Location: Muskegon Mi. http://www.mymudlife.com/profile/MIkeyWells
Send a message via Yahoo to Mikey1258
Default Set 13-14 Mud Drags & Bogg. Momsmotorsports.com
REED CITY 13/14 DRAG SAT...BOGGSAT NIGHT AND SUNDAY, TUFF TRUCK SUNDAY.
WWW.MOMSMOTORSPORTS.COM
September - Mom's Motorsports, Reed City, Michigan
13th - Mud Drags at 3:00pm - 33" Pro Street Bogg and 36" Pro Street Bogg after Mud Drags
14th - Mud Bogg and Off-Road Tuff-Truck at 1:00pm - No 33" or 36"Pro Street Bogg Classes
19th - Quad Tours Starting!
Admission: $8.00 adult | $6.00 children under 12
Pit Pass: $15.00 (good all day).
One dollar will be taken from every entry and put into the points fund . A one time fee of twenty dollars per driver and for each class entered is required to enter the points series. It will cost non-point members five dollars more per registration. Trophy Only for Factory, Cash and Trophy for Pro-Street, Cash Only for Super-Stock and Open Classes. You can enter a class at anytime prior to that class that you are going to race in starts. This includes scratches. You will not receive points for any class that you have scratched out of.
Each class will be limited to 30 entries . If a vehicle can only enter a full class than half numbers will be used. Vehicles may enter twice per class with a different driver. A vehicle can only place once per class. Including points.
To help save some time and run a efficient race some entries will not be teched in if they have been teched at one of our events before. If a vehicle is running in the wrong class and anyone questions it you will be DQed if you are in the wrong or cheating. Only Drivers may file a protest.
Mom's Motor Sports tech officials reserve the right to tech and retech any vehicle at any time during any event, any refusal will be a automatic DQ.
No refunds for DQs or cheating.
Fighting will have the same results and you will be asked to leave the
property.
All rules are subject to minor change with a majority vote of the drivers at
any event during the drivers meeting before any race starts.
NO DRUGS OR ALCOHOL IN THE PITS!!!
MUD RACING CLASSES FOR 2008
Drag Classes
Bogg Classes
Factory ANY DOT TIRE
Pro-Street ANY DOT TIRE
Pro-Street up to 33
Super-Stock ANY DOT Tire up to 36.5
Pro-Street up to 36.5
Super-Stock ANY DOT tire up to 49
Pro-Street up to 44
Modified-DOT
Super-Stock up to 36.5
Open-Cut
Super-stock up to 49
Open-Scoop
Modified DOT up to 49
Open-Tractor Tire
Open-Tractor Tire
Factory-Street, Trophy Class
__ ANY D.O.T. Tires (NO CUT TIRES)
__ Must pull 15" of vacuum a 800 r.p.m. with no type of booster assist.
__ No stripping or gutting allowed.
__ Headers allowed.
__ No open exhaust.
__ No racing fuel cells. Factory gas tanks only.
__ Must be original equipment (Ford Engine in a Ford, Chevy in a Chevy).
__ No body, frame or motor swaps allowed.
__ Lifts are allowed.
__ Tops and Doors must be on vehicle.
__ Plates and insurance are required.
This class is for stock trucks and SUV's that are driven on a daily basis
and have not been highly modified for off road use.
All vehicles in this class WILL BE TECHED AND RETECHED at every race to
ensure fairness to all entries.
Pro-Street Light
(Class 2 - Modified Stock - NMRO) Will meet Mom's requirements for this class.
__ D.O.T. Tires (NO CUT TIRES)
__ Must wieght under 3800lbs. With Out Driver. Drag classes only. Can not move up to Pro-Street Heavy. Can move up to Super-Stock and Tractor-Tire Class.
__ Must have at least 2 tires for class to run.
__ Minimum stripping and gutting.
__ Lights, windshield and wipers and wiper motors in place, brakes for each wheel of both axles are required.
__ Charging system in place.
__ All body panels and doors must be in place. (Vehicles with removable top and doors removed or with soft top and soft doors must have an approved roll bar or roll cage installed. Show bars are not acceptable).
Flat Beds allowed.
__ Any type of exhaust header with collectors allowed.
__ Open exhaust allowed.
__ Body and Frame swaps allowed. Must be factory frame.
__ OEM type transfer case only . No aftermarket or home made transfer cases allowed.
__ No Trans-brakes allowed.
__ Stock type suspension only. No Carbon Fiber Springs or Coil Over Spring Shocks allowed.
__ Bump bars and Torsion bars allowed.
__ Radiators, coolers and fuel tanks can be mounted in back of vehicle.
__ Wheels and Engine must be in stock location. (wheels in wheel wells and
harmonic balancer of engine must be forward of centerline of front axle.)
__ Carburetor or OEM (stock) Fuel Injection only.
__ Gasoline Only. NO Nitros Oxide allowed.
__ NO Aluminum Heads.
__ Transmission Blanket or Shield required.
If this class has fewer than 15 entries at any Special Event, two passes may be required.
Pro-Street Heavy
__ Weight: 3800lbs. Small Block, 4000lbs. Big Block. With Out Driver. Drag classes only.
__ Charging system in place. Alternators/Generators.
Flat Beds allowed.
__ Any type of headers with collectors allowed.
Super-Stock
(Class 3 - Super Stock - NMRO) Will meet Mom's requirements for this class.
__ D.O.T. Tires (NO CUT TIRES).
__ Weight: 2800lbs. Small Block, 3000lbs. Big Block. With Out Driver. Drag classes only.
__ Stripping and Gutting allowed.
__ Floor Pans and Fire Walls Required.
__ Factory frame. (At least 75%) No custom or home-made frames.
__ NO full fiberglass racing bodies. OEM Fiberglass replacement Doors, Fenders and hoods allowed.
__ OEM Transfer cases ONLY.
engines set back no more than 12" from center of front drive axle to #1 sparkplug.
__ Any Type Exhaust Allowed.
__ Any Type Suspension Allowed.
__ No Nitros Oxide Allowed.
__ No Aluminum Blocks Allowed.
__ Carburetors Only. No Super chargers, blowers, turbos or after-market type fuel injection allowed.
__ Gasoline Only. No Nitro Methane, Alcohol, or Fuel Accelerators Allowed.
Modified-DOT
Any body and frame
Anything goes. See General Rules.
__ Must be 4 wheel drive.
Open-Cut Tires
Anything goes. See General rules.
2 or 4 wheel drive.
Open-Scoop Tires
2 or 4 wheel drive
Open-Tractor Tires
__ Must have at least two tractor tires on rear of vehicle. No Duals.
General Rules
__ Neutral Safety Switch required for all classes.
__ Master Kill Switches required for Super-Stock and Open classes.
__ Driveshaft loops and hoops required for all classes. (except for Factory-Street).
__ Transmission Blankets or Shields required for all classes.(except for Factory).
__ All vehicles must be 4-wheel drive. (except for Open-classes)
__ Helmet, seatbelts and fire extinguisher required.
__ Roll-Bars required in all open classes or open top vehicles.
__ Clevis required at rear of vehicle for pull back. If hitch point fails
during pull-back vehicle will be disqualified.
__ Front tow hook required.
Factory and Pro street class can only move up to Super-Stock and Tractor-Tire classes.
Super Stock can move up to any Open class including Tractor-Tire classes.
If a vehicle or driver is determined by any tech official to be unsafe at
any time then the vehicle and or driver will be disqualified from racing
until requirements are met.
If anyone is caught drinking alcohol or doing drugs or is under the
influence in the pits during a race that person and their crew will be DQed
and asked to leave with no refunds.
A driver will have 30 seconds to bring vehicle to starting line when called or risk forfiture of run.
False starts will result in a DQ.
If a driver hits the timing lights they are DQed.
If a driver exits the mud pit through any undesignated boundary, gate or
lane they are DQed.
Vehicles not in neutral during hook up will be DQed.
Must stop at end of track when pulling cable or risk being DQed.
Time for tire changes will be allowed unless changes are from one vehicle to another running the same class.
NO DRUGS OR ALCOHOL ALLOWED IN PITS!
Please Remember Safety First!
The rules have been formed by the input of racers throughout the seasons. Sorry if they are not exactly what each individual wanted. We are open for suggestions. Contact us via e-mail with any suggestions you may have. Your opinion matters, but is is impossible to make a class for each individuals vehicle. The classes are formed so everyone is compatible and has the chance to win. This makes it possible to help form and enforce the rules. On behalf of Mom's Motorsports we thank-you for your continued support and look forward to another safe and fun season. Come join the fun, bring your opinions and input, but leave the petty stuff at home. We make this a fun family event.
See ya at the races!
All content in this website is property of Mom's Motorsports. All copyrights are property of their respective owners. 2001 MM
Mikey1258 is offline   Reply With Quote
Old September 9th, 2008, 11:05 PM   #2
frdboy
frdboy's Avatar
Yours back running yet Mikey??
We'll be heading up Friday afternoon
Should be a fun Weekend
Old September 10th, 2008, 09:55 AM   #3
revho
$9.00 vanilla malt
revho's Avatar
Are drugs or alcohol allowed anywhere else besides not the pits?
revho is offline   Reply With Quote
Old September 10th, 2008, 12:56 PM   #4
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
no///tonight...maybe. Were leaving friday evening, I think? No racing under the influence is the intent. So I would say wait till after the race to get tuned up!
Page generated in 0.37229 seconds with 35 queries
