Found a 9" Rear For $100 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2008, 07:32 AM   #1
Drg racr
Drg racr's Avatar
Default Found a 9" Rear For $100
Found a guy with a god 9" rear axle, but not sure what it came out of. Width is about 53" flange to flange. It has 2 dimples on the back, and a pinion snubber on the front. Where are the #'s on the housing that I can look up?
Drg racr is offline   Reply With Quote
Old September 9th, 2008, 08:10 AM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
there should be a tag saying what they are and then if not take out the 3rd member and count them
Bronco Ollie is offline   Reply With Quote
Old September 9th, 2008, 09:21 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Sounds like early Bronco, unless it has a fill plug or is missing the hump (housing is mostly round).
Should be a tag somewhere, I don't believe there are any numbers on the housing.
Old September 9th, 2008, 10:12 AM   #4
PavementPounder
PavementPounder's Avatar
http://www.ultrastang.com/Page.asp?PageID=6
Old September 9th, 2008, 11:17 AM   #5
Drg racr
Drg racr's Avatar
Housing is round, and there is a sight plug about half way up the back.
Old September 9th, 2008, 11:41 AM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Then it's probably a car axle.
Not necessarily a bad thing, it's still a 9".
Old September 9th, 2008, 12:55 PM   #7
Drg racr
Drg racr's Avatar
Cool, thanks. I'll pick it up this week sometime and dive into it. I'm going to put it in my Ranger project.
Old September 9th, 2008, 06:19 PM   #8
lil monster
BUILT NOT BOUGHT
lil monster's Avatar
Send a message via Yahoo to lil monster
No numbers on a 9in,the tag is a bolt on and is usually thrown out the first time the fluid was changed. if it has a pinion snubber on it then it came from a car. It is probably a 27 spline
lil monster is offline   Reply With Quote
Old September 9th, 2008, 06:31 PM   #9
swi dog
yeah, its a barbie jeep
swi dog's Avatar
arnt the wheel bolt patterns diffrent from car to truck?
swi dog is offline   Reply With Quote
Old September 9th, 2008, 06:36 PM   #10
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Its a crap shoot. I've seen them with both 5 on 5.5 and 5 on 4.5 patterns.
ckupq is offline   Reply With Quote
Old September 9th, 2008, 08:01 PM   #11
Drg racr
Drg racr's Avatar
Since I'm changing to a spool and a racing gear, can I run new 31-spline axles as well?
Old September 9th, 2008, 08:18 PM   #12
lil monster
BUILT NOT BOUGHT
You bet! Just have to cut some long axles down ang get them splined or order em. The housing will handle either 27 or 31.
Old September 9th, 2008, 09:04 PM   #13
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
iirc there are different bearing sizes ..
Old September 10th, 2008, 12:04 AM   #14
Blackjackbender
yes.
there are also ford 8"s that look very similar to the ford 9"
Old September 10th, 2008, 01:09 AM   #15
lil monster
BUILT NOT BOUGHT
Most likely its a 9", but here is the easiest way to tell. http://www.ridgecrest.ca.us/~biesiade/Fordrears.html.
Old September 10th, 2008, 06:33 AM   #16
fsumotorhead
N8KVB
fsumotorhead's Avatar
because of the shaft size
if he would go to 31 spline shafts, he would also now have the big bearings
Old September 10th, 2008, 02:46 PM   #17
Jeeperz Creeperz
GL 4x4 Vendors
9" came in 28-spline or 31-spline axles.
The 8" has a 25-spline pinion gear and the 9" has a 28-spline pinion gear. Also, I believe the axle housing size steps down out toward the flanges.
Another bookmark!
Old September 10th, 2008, 02:56 PM   #18
Jeeperz Creeperz
GL 4x4 Vendors
Not exactly....
The shaft diameter is the same at the bearing for 28-spline and 31-spline axles on most cars and they used the small bearing.
Depending what this axle came out of will determine if you use the small or large bearing, not what spline axle you want to use.
Old September 16th, 2008, 02:44 PM   #19
Drg racr
Drg racr's Avatar
Well, got the 9" home. It is from a Mercury Cougar, or so the guy thinks. The brake line block is on the driver's side, and it's a hair over 54" flange to flange. According to a couple websites I looked at, this matches up with a Cougar/Mustang. But, it's too wide for my Ranger. It's almost 5" wider, so I'd have to narrow it. At this point, I may not get to the truck anyway, I'm looking at moving to Tennessee.
Page generated in 0.34933 seconds with 80 queries
