cheap ways to stiffen suspension - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2008, 05:16 PM   #1
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
Default cheap ways to stiffen suspension
i really need to stiffen the KYB suspension on my kx125. but right now i dont have the time or money for a revalve. i heard putting thicker fluid in the forks help but what can i do for the rear shock? all the clickers are set stiff but its still too soft for my fatass
stevelknievel is offline   Reply With Quote
Old September 9th, 2008, 08:12 AM   #2
curt1656
Praise the lowered
curt1656's Avatar
Tighten the rear spring, put spacers in front springs. Not the best way but free.
Old September 9th, 2008, 08:50 PM   #3
stevelknievel
Fuck Cancer
alright ill try that. i set my sag but screw it i need it stiffer
thanks man
Old October 21st, 2008, 02:37 PM   #4
KTM Mike
when they say "tighten the rear spring" that means the preload collar. For your forks - I would still try a slightly heavier oil, and play with clickers - dial in more compression dampening. Keep in mind, if you are to heavy for spring rates, these sort of changes can result in overly harsh suspension and other handling quirks. Best bet is to make sure your spring rates are correct for your weight.
KTM Mike is offline   Reply With Quote
Page generated in 0.16289 seconds with 35 queries
