94 chevy transmission shifting problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2008, 11:11 PM   #1
coyne
coyne's Avatar
Default 94 chevy transmission shifting problem
v=8 auto stock,stays in drive in all gears even reverse and park it stays in park but you can tell its still in gear all forward gears work good ,in reverse it still goes forward and in nuetral any ideas
coyne is offline   Reply With Quote
Old September 8th, 2008, 08:43 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
shifter linkage fell off the valve body? pull the pan and look. will it shift through the gears or stays in high gear?
Old September 8th, 2008, 09:17 AM   #3
Tom
Because racecar
Tom's Avatar
x2 Or the forward clutch is so burnt that it locked itself up.
Old September 8th, 2008, 06:21 PM   #4
coyne
coyne's Avatar
Default it shifts 1st,2nd,3rd, od
then it will down shift all fine you can tell it is in drive while in park ....but pak does work
Old September 9th, 2008, 09:43 AM   #5
Tom
Because racecar
Tom's Avatar
Did it work fine before the fluid change? I suggest pulling the pan back down and make sure the filter didn't smash or pinch any wiring.
Page generated in 0.58981 seconds with 38 queries
