chevy big block blowing smoke - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2008, 11:48 AM   #1
beejers
always building
beejers's Avatar
Default chevy big block blowing smoke
i bought a '93 chevy with a 454 and nv4500, pretty cool.
the guy said there was about 60,000 on the motor, had to put plugs on and runs real strong.
only driven it a dozen times or so since i bought it 4 months ago.
today i take off and shift and POOF,,,,,,,,,SMOKE (blue smoke,like oil)
every time i shift, POOF
rev it up ,POOOOF
what could cause this? Seems wierd to me that last time i drove it i didnt notice anything, today you could see it from a 747 flight over michigan.
beejers is offline   Reply With Quote
Old September 6th, 2008, 12:19 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
valve seals worn/cracked...pcv system sucking oil...clogged return oil passages causing the valve cover to fill with oil and drain down the worn valve seals
Old September 6th, 2008, 03:13 PM   #3
2kids=nojeepmoney
any chance you overheated? i did that in a waggie once. overheated it (not bad) but then it wouldn't stop smoking... ended up pulling it and selling it as a core (pavement pounder probably ended up with it)
2kids=nojeepmoney is offline   Reply With Quote
Old September 6th, 2008, 08:28 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Start up smoke is ussally valve seals. if its shift smoke its either bad valve guides or rings or both. I have seen bad guides suck oil like a hoover.
Yetti
Page generated in 0.14847 seconds with 35 queries
