D44/D60 cj7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2008, 09:11 AM   #1
Cj7Ed
Default D44/D60 cj7
Im looking for a set of axles i can basically drop under my cj7 NT, other than having to move the preches, run lines etc. pref. id love to have a set of 60's but a 44F and 60R will work. located in farmington hills, dont really wanna drive more than 1-2hr away.
Cj7Ed is offline   Reply With Quote
Old September 5th, 2008, 09:57 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have a Dana 44 front that will drop in, with 8 lug parts it will be 63.5" wide. Housing, flat tops knuckles, caliper brackets and the short side axle shaft and stub, needs a long side but is a factory length and gears/carrier(locker). $250
Would go great with a CC 14 bolt rear or a early 70's Ford rear 60.
Old September 5th, 2008, 09:59 AM   #3
jeepcj
breakin frogs legs
jeepcj's Avatar
I have a complete dana 60 rear with 3.54 gears for $150, out 1979 ford.
jeepcj is offline   Reply With Quote
Old September 5th, 2008, 10:16 AM   #4
Cj7Ed
I need something along the line os 51-52 wms-wms a little longer wouldnt hurt forgot to add its a NT axle. I have a rear dana 44 thats 52 wms-wms. so really am only in need of front but a spare for the rear wouldnt hurt. If i can get a matching set or wider axles i will go with that.
Old September 5th, 2008, 11:11 AM   #5
Jeepaholic
Jeepaholic's Avatar
Alright, I have a 54" wms dana 44, housing, short side, and a long side that needs cut down or it is also a factory length shaft. $150 or $225 with flat top knuckles. For $200 more I have big brake cj outers and alloy stubs to complete it.
Page generated in 0.14814 seconds with 38 queries
