5 psi, too low? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2008, 09:41 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default 5 psi, too low?
I have an 89 bronco with a 4.9, was having problems with the gauge going down to nothing. I hooked up a mechanical gauge and warmed up and at idle it reads about ~5psi. I am running 10w-30, and suggestions on boosting it up other the running stupidly high weight oil?
Old September 3rd, 2008, 11:15 PM   #2
xjmichigan
xjmichigan's Avatar
How many miles on the motor?
Break out the Plastigage, check the main bearings.
Old September 3rd, 2008, 11:24 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
general rule, 10psi for every 1k. So yes your bearings are most likely washed out. Throw in thicker oil to see if that helps... could also be a oil pump issue.
Old September 4th, 2008, 11:57 AM   #4
Bones
Bones's Avatar
yes, thats too low
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 4th, 2008, 03:23 PM   #5
IDIeselman
IDIeselman's Avatar
Change that 9 year old oil filter when you change the oil and you will be fine,
If you are not having any rattling at start up your bearings are good.
Old September 4th, 2008, 04:31 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Already changed the oil and filter, and still does the same thing.
Page generated in 0.23131 seconds with 41 queries
