anyone esle have any new "cold leaks" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2005, 03:33 PM   #1
Bones
Bones's Avatar
Default anyone esle have any new "cold leaks"
I swear, every damn winter somone's transmission in my family gets a new leak when the first cold front move in. this year its the trans on my diesel. the aluminum pans tend to leak first with the cold... I am hoping its only the trans pan gasket... but we'll see.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 16th, 2005, 08:11 PM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
No but my wifes tires are low every other day on the wifes Suburban.
Old November 16th, 2005, 09:20 PM   #3
geor
My Custom Title
Mine just leaks constantly.
geor is offline   Reply With Quote
Old November 19th, 2005, 07:40 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I just wanted to say the cold is doing you a favor, its showing you the weak points in your vehicle, just remember if oil can get out..water can get in.
the fact the oil seals leak means the sealing surface is flawed, the seal bends to meet the flaws when warm and then returns to its original shape when cold.
Yetti
Old November 20th, 2005, 04:44 PM   #5
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
aluminum is affected by temp 2 times more then steel too
GMCsonoma94 is offline   Reply With Quote
Old November 29th, 2005, 11:57 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
this is absolutely correct imo
http://www.apalansing.com/
Old November 30th, 2005, 04:46 PM   #7
Bones
Bones's Avatar
I disagree to a point. Most of my leaks are caused by pressure inside the case/motor/whatever. Unless the atmosphere's pressure somehow increases rapidly, a lot of these leaks won't reverse... but if the atmosphere takes a crap and does, I doubt I will care how much fluid I am loosing lol
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 30th, 2005, 05:34 PM   #8
5.9zj
5.9zj's Avatar
yep. the wifes saturn leaks antifreeze every year when it starts to get cold.
5.9zj is offline   Reply With Quote
Page generated in 0.28893 seconds with 47 queries
