2.9 ticking time bomb.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2008, 08:23 PM   #1
88mudder
In the band!
Default 2.9 ticking time bomb..
well here's the situation..
2.9 v6 in a 88 Bronco II. The motor has 150k on it. It has never had any lifter tick or knocking until i get home from the Mounds..I got stuck in a hole there and im sure water got sucked in through the intake. Eversince that time my engine has had BAD ticking and knocking.
Changed the oil twice...added some Lucas in there..this silenced the ticking but after about a week it came back in full force..
Any tips to keep the engine alive? It ran so good before..and was really quiet and smooth.
Old September 1st, 2008, 09:43 PM   #2
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
try dropping the oil pan enough to remove and clean out the oil pick up tube. this happened to a b2 my buddy had. it was a common problem on the 2.9s. you can unbolt the motor mounts and use a 4x4 and jack the motor up enough to drop the pan out of the way.
jpr Jeremy is offline   Reply With Quote
Old September 1st, 2008, 10:09 PM   #3
live with it, more 2.9Ls tick then don't tick.....i have put thousands of miles and tons of abuse to 2.9Ls that ticked
Old September 1st, 2008, 10:28 PM   #4
88mudder
In the band!
thats what im thinking..or do a engine swap after my Ranger is finished.
Old September 1st, 2008, 10:53 PM   #5
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
yeah all 2.9's have some kind of tick no matter what
Bronco Ollie is offline   Reply With Quote
Old September 1st, 2008, 10:54 PM   #6
88mudder
In the band!
thats what ive been hearing all these years...
Old September 1st, 2008, 10:56 PM   #7
Bronco Ollie
lol yeah all 3 b2's that i have had ticked lol i put diesel oil in one of them and that stopped the tick for about 2 weeks but then it came back
Old September 1st, 2008, 10:59 PM   #8
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
Mine had a fuel injector tick i was told. But the guy who told me knows a ton about fords. That might be the ever present ticks in the 2.9s
Bronco351 is offline   Reply With Quote
Old September 1st, 2008, 11:01 PM   #9
Bronco Ollie
in the early b2's you can adjust the rocker arms and that help the tick go away also
Old September 1st, 2008, 11:43 PM   #10
88mudder
In the band!
the tick gets worse at the engine temp gets hotter. The Lucas does help, tho. Ill live with it.
Old September 2nd, 2008, 07:27 AM   #11
its the lifters that tick
Old September 3rd, 2008, 03:30 PM   #12
Drg racr
Drg racr's Avatar
I agree, it's the lifters. They get loose after a lot of miles. My 2.9 has 99000 on it, and it just ticks when you first start it cold. The rest of the time, its quiet.
Drg racr is offline   Reply With Quote
Old September 3rd, 2008, 03:58 PM   #13
88mudder
In the band!
Do 1988 2.9's have adjustable rockers?
Old September 3rd, 2008, 04:09 PM   #14
Bronco Ollie
i think up to 86 they have the adjustable lifters and thats what i ment when i said rockers
Old September 4th, 2008, 09:48 PM   #15
Jdc215
Jdc215's Avatar
my bii has 150,000 and i havent noticed any motor tick. and yes i do know what it sounds like, my 94 rqnager had 280,000 miles on the vulcan 3.0 and it ticked incessantly. ran great though, untill i broke a shift rod in the transmission. then she made the long trip to Regal's Recycling for a total net of $425.00
Jdc215 is offline   Reply With Quote
Old September 4th, 2008, 10:05 PM   #16
Nuggets
I fix stuff!
Nuggets's Avatar
I believe the 2.8s had adjustable rockers, the 2.9s are hydraulic.
Old September 4th, 2008, 10:15 PM   #17
Bronco Ollie
to stop the ticking you have to adjust the lifters it is the lifters that tick like cheapthrillb2 said and i think only up to 86 you can adjust them
Old September 4th, 2008, 10:38 PM   #18
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
my 93 expo did the same thing was told it only had like 40,000 on rebuild but it was gutless and got spanked by a 2wd splash sold that piece and never looked back
98ZJ318 is offline   Reply With Quote
Old September 4th, 2008, 11:46 PM   #19
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
drive it till she blows
Old September 5th, 2008, 12:55 AM   #20
skife
skife's Avatar
lifter tick!
2.8's valve lash is adjustable
2.9's valve lash is not adjustable.
also i had a '92 tempo with a 3.0 vulcan in it, the thing rattled and ticked like no other, but it was paired with a 5speed transmission and i beat the hell out of it for the 8 months that i owned it. 142k on it and it was reliable enough to take me to ohio and back... alot.
Page generated in 0.57395 seconds with 83 queries
