appropriate alternator following 1.6 swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 31st, 2008, 09:26 PM   #1
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
Default appropriate alternator following 1.6 swap
after doing my 1.6 swap i will need an alternator (don't have the one from the 1.6). the pulleys on the tracker motor have the wider serpentine belt, and not a v type belt. anybody use a GM or something that is compatable with this type of belt config?
jeepman784 is offline   Reply With Quote
Old September 1st, 2008, 07:07 PM   #2
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
there is a kit to use a gm ault otherwise there ia a wrecked tracker at the holland lkq with a ault on it.
hman1991 is offline   Reply With Quote
Old September 1st, 2008, 07:11 PM   #3
kickstand
circling the drain
kickstand's Avatar
WTF did he just say?
Why not run the alternator that comes on the 1.6?
Old September 1st, 2008, 08:31 PM   #4
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Cost prohibitively nonsensical. You can use any GM clockwise rotation GM alternator, with serpentine belt pulley, just the belt will only fill 4 of the 5 grooves for the belt. Proper alignment is key, as the GM alternator likes to eat lower brackets.
Or, you could change your belts over to V groove, and use any of thousands of GM alternators, the 55 and 63 amp models being the most popular for swapping. Zuwharrie.com has wiring specifics for hooking up the new alternator, as there are slight differences in the hookups.
If you have power steering or air conditioning, you will need to keep your serpentine belt hookup, and what I usually do is to take a stock samurai water pump pulley, and spin the center of it out with a lathe, and flip it inside out, welding it to the stock crank pulley, they are perfectly self aligning, and its an easy mod. If you are going the serpentine belt route, grab a second water pump pulley from a tracker, and perform the same pulley stacking trick.
For you guys using a stock samurai crank pulley with a/c to run your power steering, pay attention. The larger stacked pulley puts many more RPM to the power steering, making turning many easiers.
zook94 is offline   Reply With Quote
Page generated in 0.24859 seconds with 35 queries
