Toyota Solid 8" Axles - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2008, 04:51 PM   #21
aimmotorsports
aimmotorsports's Avatar
is the kit from sky to use the ifs hubs the only one? i cant find anything else.
aimmotorsports is offline   Reply With Quote
Old March 4th, 2008, 06:22 PM   #22
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Honestly, no one runs the Birfield Eliminator kits anymore. Longfield super axles are as strong as you can make mini truck front axles.
Asian Hubs are actually stronger then any other aftermarket hubs available for toyota's.
JcrOffroad.com
Like us on Faceook!
Old March 4th, 2008, 06:45 PM   #23
Believe he's referring to the hubs, not the hubs, not the lockouts.
The hubs just go on the spindles in place of the solid axle spindles. The 'kit' I believe is mainly a spacer ring to put the brake rotor somewhere that it lines up with the calipers.
I think on pirate4x4, you'll see a few diffferent ways to use IFS hubs and get the rotors in place. Some are a little hokey, though.
Old March 4th, 2008, 08:10 PM   #24
aimmotorsports
ill take a look. was looking there and didnt see anything... must not of looked hard enough though
Old March 4th, 2008, 08:24 PM   #25
Te thread is here:
http://www.pirate4x4.com/forum/showthread.php?t=515697
Thats all about IFS hub bodies. Its in the FAQ, under F for front axle. Sometimes they put things in wierd spots. I'f have thought under H for hubs..
Old March 6th, 2008, 06:55 PM   #26
Here's another recent writeup about how to use IFS hubs with no spacer:
http://www.pirate4x4.com/forum/showthread.php?t=660179
Old September 13th, 2008, 11:23 AM   #27
cruiserjg
dodge man
cruiserjg's Avatar
Default More info
I thought this was a good info for hear.
http://www.birfield.com/~morgan/tech/axle/
cruiserjg is offline   Reply With Quote
Old September 13th, 2008, 04:41 PM   #28
J/T
J/T's Avatar
Send a message via Yahoo to J/T
I know this is an extremely old thread but I was wondering what would be the biggest
tire size I could run on stock '85 toyota 8" axles without braking anything.
J/T is offline   Reply With Quote
Old September 13th, 2008, 04:44 PM   #29
brimy311
brimy311's Avatar
Stock front axle without a locker will work with up to 33's. But be aware that stock birfields are GARBAGE! If you put longfields in, you could run up to 37's and a locker. I have seen 38's on stock rear shafts and no breaks. I still run stock rear shafts. The weak link with stock axles are the factory birfs.
JcrOffroad.com
Like us on Faceook!
Old September 13th, 2008, 04:49 PM   #30
J/T
J/T's Avatar
Thanks for the info, this is my first vehicle and I'm going to need to drive it every day so I need it to stay in one piece.
Old September 13th, 2008, 08:36 PM   #31
Yeah, 33s sounds about right. 35s you can do, but want to be careful, especially when turned. I have been pretty good with 38.5s on heavy steel beadlocks with longfields up front, stock rear axles. Have broke something up front, but it was deserved.....
Old September 14th, 2008, 07:28 PM   #32
cruiserjg
dodge man
cruiserjg's Avatar
Default More good info
PRODUCT / ................................................. FT.LB. TORQUE/.... % TWIST
Yukon 4340 Dana 60 35 spline short side axle.........12,000 ..................130
Stock Dana 60 35 spline short side axle .................6,500 ....................35
Yukon 4340 Dana 44 30 spline short side axle ..........5,800 ...................35
Stock dana 44 30 spline........................................5,00 0.....................35
Yukon 4340 Birfield Eliminator kit (ear failure)............5,500......................50
Longfield 4340 30 spline (shaft failure)......................8,500............... ......175
Longfield 4340 27 spline........................................6,50 0.....................75
Stock Toyota Birfield.......................................... ..4,200 .....................45
Stock Toyota Inner Axle.......................................5,000 .....................45
All Pro "Profield".................................... .... .......... 3,500 ....................30
Stock toyota Transfer Case Output Shaft.................2,500 ....................65
Longfield treated Transfer case output shaft.............2,500.....................20
Longfield 4340 Transfer Case Output Shaft...............4,000......................25
All Pro Transfer Case Output Shaft..........................2,500 ......................60
Marlin "treated" Transfer Case Output Shaft..............2,500 ......................10
Stock Toyota Hub............................................... .5,800/
Longfield Treated Toy Hub ....................................6,800/
Stock Toyota Flange............................................ .6,000/
Longfield 4340 Flange............................................ Didn't test
Old April 4th, 2009, 08:05 PM   #33
MSG101
Default Broken 1990 4runner rear axle question
Hi, Is it possible to use a v6 axle housing off a 1990 4runner on a 1990 4runner 4cyl? My tracbar weld broke and I re-welded it but it snapped again and I was wondering if I can just install the v6 axle into my 4cyl 4runner and use the 4cly diff and axle shafts in the v6 housing?
Thanks for any feedback,
Matt
MSG101 is offline   Reply With Quote
Old April 4th, 2009, 09:12 PM   #34
Yep, they are the same. The onlt difference is in the 3rd members themselves. Housing/shafts are the same.
Old October 4th, 2009, 08:36 AM   #35
katoom
katoom's Avatar
does anyone know if the 3rd member from a 88 v6 truck fit in the 96+tacoma housing?
katoom is offline   Reply With Quote
Old November 26th, 2009, 07:53 PM   #36
cruiserjg
dodge man
cruiserjg's Avatar
No
Old April 1st, 2012, 07:06 AM   #37
sniperperformance
I'v been looking for a rear toyota axle ifs width. i found one in a local you pull it yard. its in a 96 toyota 4runner. anyone have any info on it. im not trying to find out it gear ratio. just 8" or 7.5" / 2 pin carrier or 1/ is it also 6 on 5.5 lug pattern.
the place was closing after a all day junk yard journey trying to find something so i couldn't get much info.
sniperperformance is offline   Reply With Quote
Old May 21st, 2012, 07:31 PM   #38
95T-100
Default T100 sas
i need some help on finding out where i can get a solid axle to fit a 95 t100. has anyone done this if so how and what axle was used? Please Help!!
95T-100 is offline   Reply With Quote
Page generated in 0.34019 seconds with 77 queries
