Toyota Solid 8" Axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2005, 04:10 PM   #1
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Default Toyota Solid 8" Axles
Figured we needed some toyota axle info :)
Axle Id
Toyota 4x4 Front solid axles
-6 lug 6 on 5.5"
-8" ring gear
-Removable center section(3rd member)
-30 Spline front shafts, they neck down to 27 spline into the birfields
-birfields, basically an early version of a CV shaft. Designed not to bind like Ujionts do when driving in 4x4.
-Trunion/Kingpin/Knuckle, no ball joints.
-Stock Aisin Locking hubs are very stout, usually only replaced for drive flanges.
Toyota 4x4 Rear Solid Axles
-6 lug 6 on 5.5"
-8" ring gear
-30 Spline axle shafts
-86'-93' Toyota rear axles are beefier and wider then 79'-85' toyota rear axles
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
Toyota 8" diff
Toyota diff info:
http://home.4x4wire.com/erik/diffs/
JcrOffroad.com
Like us on Faceook!
Old November 16th, 2005, 04:15 PM   #2
brimy311
brimy311's Avatar
Toyota aftermarket upgrades:
www.toyotasuperaxles.com
Chromoly 30 spline super birfields and axle shafts.
They eliminate the neck down on the shaft as well
www.marlincrawler.com
Billet Hi steer arms
Or Forged Steering arms
Factory Electric locker and Hi pinion diff:
Offered on landcruisers (fj80) are Front Hi pinion diffs
Also available is the toyota Hi pinion Electric locker
Standard Low pinion Electric lockers were available with the TRD options on Tacoma's and 4runners.
JcrOffroad.com
Like us on Faceook!
Old November 16th, 2005, 04:21 PM   #3
brimy311
brimy311's Avatar
Vented rotor swap
Solid toyota front axles come with solid (unvented) rotors
By buying rotors from '81 and up Toyota LC FJ40 and fj80
and calipers from an IFS Toyota (86+ P-up or 4Runner).
You can swap to vented rotors. Does not add any width to the axle.
Rear Disc brakes
Rear disc's are pretty straight forward on toyota rear axles.
http://www.sky-manufacturing.com/
These guys sell caliper brackets that bolt on
or you can build your own
Many ppl have done them diffrently using different parts, but most us chevy 1/2 ton front rotors and calipers from chevy S10 or if you want an ebrake Cadillac Eldorado.
Tons of info here:
http://www.pirate4x4.com/forum/showthread.php?t=281059
JcrOffroad.com
Like us on Faceook!
Old June 19th, 2007, 02:39 AM   #4
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I know this post is old but were would a good place be to find Toy front and rear solid axles? PLaying with the idea of putting them under my ZJ.
nick_n_ii is offline   Reply With Quote
Old June 19th, 2007, 08:49 AM   #5
They are a bit narrow for a ZJ.
ZJ axles are about 60" WMS/WMS, Toy fronta are 56", the rears are 55" although later one sare 58.5"
If you really want a Toy axle, the late model 4 runners were 60" wide. You could put spacers on the front to get it to 59- 60" or so. My currnet front is 59" with spacers, but I've got a 62" wide custom built housing thats going under it.
Old October 24th, 2007, 01:18 PM   #6
landrollover
landrollover's Avatar
Send a message via AIM to landrollover
Whats the difference between 4 cyl rear third and 6 cyl rear third?
landrollover is offline   Reply With Quote
Old October 24th, 2007, 01:25 PM   #7
brimy311
brimy311's Avatar
All pre-'95 4-cylinder 4wd mini-trucks & 4Runners use the Toyota 8" 2-pinion differential front and rear (except turbo models). This is known as the "4cyl diff." This diff is by far the most common diff in older Toyotas.
Ten 10mm ring gear bolts, 27 spline pinion shaft.
4cyl Turbo and V6* 4Runners and mini-trucks use the Toyota 8" 4-pinion differential in the rear. This diff is known as the "V6/Turbo diff." It has larger carrier bearings, is generally stronger than the standard 4cyl version, and is a direct swap into axles that use the 4cyl 8" diff. Separate gear sets are made for the V6 style diff (only from Toyota and Precision Gear), but cheaper, more readily available 4cyl style gears are commonly made to fit- the only difference being a very slightly larger pinion gear on the V6 style gear (the actual strength difference in gear sets is debatable). The strength increase in this diff over the 4cyl diff comes mainly from the beefed up housing, which stiffens the entire assembly, keeping the gears in proper (stronger) alignment.
Although somewhat rare, there is a version of this diff that came from the factory with 4.88 gears. The carrier (3rd member housing) has a different pinion offset so that the ring gear doesn't need to be as thick. This means that no gears other than the factory 4.88's will fit this particular diff. However, diff cases, commonly called carriers (factory, LSD, lockers, etc.), for the standard V6/Turbo diff should be interchangeable (4cyl and V6/Turbo carriers are NOT interchangeable).
More diff. info here:
JcrOffroad.com
Like us on Faceook!
Old October 24th, 2007, 01:37 PM   #8
landrollover
thanks
Old November 2nd, 2007, 01:45 PM   #9
Geoff
Geoff's Avatar
How hard would it be to put toy axles under my TJ....would it be cheaper/e-z-er then other opions
Geoff is offline   Reply With Quote
Old November 2nd, 2007, 04:04 PM   #10
Talk to Nyxis, he has them. They are narrower than TJ axles, wrong side diff, wrong wheel pattern, leaf spring, etc...
Old November 11th, 2007, 03:47 PM   #11
brimy311
brimy311's Avatar
Actually not even close lol. It is a TJ tub on a YJ frame with an entire Toyota driveline.
JcrOffroad.com
Like us on Faceook!
Old November 11th, 2007, 03:50 PM   #12
brimy311
brimy311's Avatar
I have received alot of enquiries about compatability for other makes and models. Just like any other axle, it will require work to install. They are not going to bolt into anything else.
For TJ's, YJ's they are narrower and axle drops on the wrong side of the vehicle. Alot of Dana 44's would be better canidates for those jeeps.
JcrOffroad.com
Like us on Faceook!
Old November 12th, 2007, 10:01 PM   #13
Stan
I got a gold chain
Stan's Avatar
So what you're trying to say is my YJ is far superior than your toyotajeep.
Stan is offline   Reply With Quote
Old November 12th, 2007, 10:13 PM   #14
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
well more superior then my toyotajeep
nixxerRsixxer is offline   Reply With Quote
Old November 12th, 2007, 10:25 PM   #15
brimy311
brimy311's Avatar
Yep, that is exactly what I was getting at.
JcrOffroad.com
Like us on Faceook!
Old January 3rd, 2008, 07:58 PM   #16
jeepinboy70
wannabe
jeepinboy70's Avatar
Send a message via Yahoo to jeepinboy70
I put a set of 84 yota axles (4cyl p/u) in my 93 yj. just needed to get offsets on the rims to make up the differance. But, I also have a chevy drivetrain in it with a d300. Was a lot of fun doin it, especially when i was told "you can't do that!" lol...
I've got a detroit in the rear, open front. 4:11's. 35" boggers. I've had a couple of ring gears in the rear that I gernaded, but other than that. I love em! Goin on 4 years now.
jeepinboy70 is offline   Reply With Quote
Old March 1st, 2008, 05:57 PM   #17
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
What all is involved in putting ifs hubs on a 79-85 front axle? Im looking to get a little more width out of mine. What all would i need for parts
Old March 1st, 2008, 11:26 PM   #18
aimmotorsports
aimmotorsports's Avatar
sky-manufacturing has a kit for like $200. but you still need hubs. im looking into it. seeing if i can find something cheaper though...
aimmotorsports is offline   Reply With Quote
Old March 1st, 2008, 11:34 PM   #19
Mud'N'Truck
O ive seen that before. I thought it was somthing different like putting the whole ifs knuckle assemble on there or somthing.
Old March 2nd, 2008, 09:45 AM   #20
Or just use spacers. Either way, the leverage on your bearings and scrub radius are the same.
Page generated in 0.74427 seconds with 83 queries
