explorer straight axle swap???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2008, 08:23 PM   #1
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
Default explorer straight axle swap????
have a 94 explorer, 8 inches of lift, 36s. want to do a straight axle swap in the front. did some measuring, and a cherokee axle is only 1/4 inch wider, any info, ideas. whats the easiest or the best swap. would like to do the cherokee for the after market support.
lososjoyride00 is offline   Reply With Quote
Old August 30th, 2008, 08:30 PM   #2
88mudder
In the band!
early bronco dana44, bolts right in for the most part.
Check out the tech library at www.therangerstation.com
Old August 30th, 2008, 08:42 PM   #3
yeah EB D44 real simlple least amount of work......then just get lug adapters to convert the rear bolt pattern and all set.
36's and a D30 untized bearing and no hub locks just sound like a bad idea..
Check out holshotracers build in the rig builds section (Explanger Build) his frame is a explorer frame so it is the same as yours (from the mid section forward, his is a 4dr). He just has a ranger cab on the explorer frame. Hes basically has a EB 44 coil sprung etc.
Old August 31st, 2008, 12:08 PM   #4
88mudder
In the band!
goodluck finding a cheap d44 with disks...its the whole reason why i decided not to do the swap.
Old August 31st, 2008, 12:32 PM   #5
thats why we started with a 77 f150 FW D44 and had the pass shortened to EB width (6"s removed from axle tube). The Left side of the f150 d44 and the eb are within an half inch if i remember correctly.
Old August 31st, 2008, 09:05 PM   #6
lososjoyride00
thanx for the info
Old August 31st, 2008, 09:29 PM   #7
i run the same axle in my B2 (basically same front frame dimensions) as a Full width 44 coil sprung and now the basically a eb 44 leaf sprung. It really is very easy to set-up a coil sprung SAS under a explorer using a eb or even a fw 44
Old September 1st, 2008, 12:20 AM   #8
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
It wasnt to bad but make sure to build ext Radius arms, i opted for full with Sas under my ranger and really wish i would of built Longer Radius arms.
Old September 2nd, 2008, 10:17 AM   #9
fsumotorhead
N8KVB
fsumotorhead's Avatar
I would do like the others mentioned with the 44
otherwise you are replacing a D35 with a D30
The TTBs have their place, they aren't that bad when set up correctly for what you want to do
Page generated in 0.21545 seconds with 50 queries
