Another swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2008, 12:51 PM   #1
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
Default Another swap question
swapping a 1.6 into my '87 sami. Still have to locate a few parts (distributor, starter, alternator), but was wondering about the removal of my 1. 3
anyone have tips on how to remove the least amount of stuff from the carb etc. do i have to take off the entire intake and remove in order to get the motor out of the truck? i just know i will screw something up trying to re-hook eveerything back up, and vacuum lines suck. hopefully in the future i will be able to eliminate some of those stupid lines.
thanks all
ill post some pics up soon
jeepman784 is offline   Reply With Quote
Old August 30th, 2008, 02:50 PM   #2
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
i take it you are leaving it carbed then?
hman1991 is offline   Reply With Quote
Old August 30th, 2008, 05:18 PM   #3
jeepman784
jeepman784's Avatar
yes, i am... wanna get it running before i make decisions on fuel delivery. long term am thinking propane
Old September 1st, 2008, 08:42 PM   #4
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Take pictures with a digicam of the vacuum hose routing, and then use masking tape and a permanent marker to clearly label every vacuum connection, and put clear tape over the words, so if you get dirty fingers, you can wipe off the clear tape, being able to read the tags you worked so hard to make.
The wiring plugs are all color coded, and only go on one way, so any 5th grader can perform the electrical side of things.
You can pull the intake off, in one single piece, only having to disconnect the coolant hoses from the choke, they will be too short to reach. Your 1.6 will not have a lobe on the camshaft for your mechanical fuel pump, and there is a small sheet metal cover over the hole. You need a quality low pressure electric fuel pump, and a fuel pressure regulator that is accurate to 3-4 PSI. Steer clear of the Autozone crap.
When you get ready to drop in the 1.6, keep posting any questions you come up with, its been done, and we can help.
zook94 is offline   Reply With Quote
Old September 13th, 2008, 02:05 PM   #5
cruiserjg
dodge man
cruiserjg's Avatar
pm me when you want to convert to propane. Much better the FI. and cheper to run. I will get you a good price.
You sould post pics of your swap.
cruiserjg is offline   Reply With Quote
Page generated in 0.24897 seconds with 38 queries
