Unit bearing D60 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2008, 10:34 PM   #1
Bones
Bones's Avatar
Default Unit bearing D60 question
simple question... what supports the axle shaft on a unit bearing axle?
On a kingpin, there are needle bearings on the inside of the spindle....
here is the deal. I have a "squel" on the right front of the D50 in the tow rig. I think it happens when the axle shaft (that isn't turning) rubs part of the unit bearing (that is turning). When I lock the hub in (so the shaft is turning witht he hub), the noise goes away. I thought it was the hub, so I swapped the left and right hubs, and the noise stays with the right side.
Is there a bearing between the unit bearing and the shaft? If so, is it servicable or is it an assembly to the unit bearing. Or is there a bearing that sit in the axle tube toward the C?
sorry this is a newbie Q... I've never had a unit bearing axle apart.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 28th, 2008, 11:25 PM   #2
junk90xj
ALLPRO AUTO
junk90xj's Avatar
does it have the vac disconect hubs?
http://www.apalansing.com/
Old August 28th, 2008, 11:27 PM   #3
Bones
Bones's Avatar
no, man hubs
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 28th, 2008, 11:41 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Your unit bearing is bad you have to replace it
The unit bearing supports the axle
Old August 29th, 2008, 12:14 AM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
^^^what he said.
Old August 29th, 2008, 05:06 AM   #6
beejers
always building
beejers's Avatar
there is a small needle bearing on the inside of the unit bearing.
beejers is offline   Reply With Quote
Old August 29th, 2008, 07:58 AM   #7
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i will buy your old unit bearing for 20 dollars
Old August 29th, 2008, 08:12 AM   #8
Tom
Because racecar
Tom's Avatar
x2 They will rust up, they sometimes take out the stub shaft as well, you can buy that bearing separate.
Old August 29th, 2008, 09:08 AM   #9
Bones
Bones's Avatar
Originally Posted by junk90xj View Post
^^^what he said.
I fully understand teh Unit bearing supposrts the weight of the vehicle via the hub, but that isn't the problem. I was asking what supported the stub shaft as it was passing throught the ID of the hub.
Thanks, I called NAPA and the guy knew the part number withought even looking it up. hopefully I'll have time to swap it tonight before I drive to Alpena. I *think* the SKF number was B2110.. about $10 or maybe less.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.19747 seconds with 50 queries
