Power steering pump question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2008, 07:02 PM   #1
vb20002
Default Power steering pump question
I recently purchased a new Sidekick power steering pump for my Samurai the pump did not come with the pressure release valve which sits on top of the pump, and my old valve leaks, can i just cap this hole or do i need the valve? Where can i find a valve the LPS cannot get one.
vb20002 is offline   Reply With Quote
Old August 30th, 2008, 01:42 AM   #2
superduty03
superduty03's Avatar
bump.... someones gotta have an answer for this... help us out!!!!!
superduty03 is offline   Reply With Quote
Old August 30th, 2008, 02:52 PM   #3
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
you try the dealer. if you take a pic of what you need i can pull it off my treacker pump that is siezed for you. ill be replacing it in a week or 2 but if it is ez to pull of b4 that ill do it for ya.
hman1991 is offline   Reply With Quote
Old August 30th, 2008, 06:01 PM   #4
vb20002
Ill get a pic for ya thanks.
Old September 1st, 2008, 10:58 AM   #5
scarboni
i welded the hole closed on mine and its worked fine for over a year. beware if you run tires over 31's your gonna need a cooler and over 33's and this pump sucks when aired down off road.
scarboni is offline   Reply With Quote
Old September 1st, 2008, 11:00 AM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
If you eliminate the relief valve and something restricts flow, pump go boom.
Old September 2nd, 2008, 11:57 AM   #7
vb20002
I have a cooler i think im going to weld the hole closed there is only one dealer i can find around here that might be able to get the part and there 3 hours away, should i remove the spring and all the other stuff under the relif valve when i weld it?
Old September 5th, 2008, 08:59 AM   #8
1badzuk
1badzuk's Avatar
didnt you see that! BOOM that dosent sound good. i wouldnt want to drive that or be on a trail with it. just keep looking at junk yards be safe
1badzuk is offline   Reply With Quote
Old September 6th, 2008, 03:35 PM   #9
superduty03
the only thing that would cause a need for pressure relief would be holding the steering maxed to the left or right which is fixed by stops.... so I say go for it and ill wheel with you any day!!!!
Old September 9th, 2008, 10:22 PM   #10
vb20002
I've been looking for that pressure relief valve for over a month checked every junk yard on Dort Highway with no luck. I even called the Suzuki dealer in Traverse city and they couldn't even get the part, and PSC wasn't sure about the valve either. So i welded it and it's been working good but only time will tell.
Page generated in 0.29306 seconds with 53 queries
