Project YJ for sale - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 27th, 2006, 07:22 AM   #1
XJeeper
misfit
XJeeper's Avatar
Default Project YJ for sale
92 YJ tub/frame, back halfed and dove tailed. 125ft of 1.75" x .120 wall DOM tubeing makes up the cage, grill hoop, shock hoops, rocker gaurds and hood bars. 1.5" DOM is mixed in for smaller bars and gussets.
  • Ford 5.0L HO from 89 Mustang w/computer and harness
    • Ford small Bell C6 w/fresh rebuild from KB
    • Chevy Kingpin D60 front with 4.10s
    • Ford D60 rear, gutted, but has BTF truss and 4-link brackets
    • Freshly gone thru D300 with clocking ring, stock outputs.
    • DANA 5.86 ring and pinions (2)
    • DANA 35 spline open carriers (2) for above gear sets
    • 4- 2" solid 7075 aluminum lower control arms
    • 6- 1.5" 7075 solid aluminum upper control arms
    • 16 QA1 3/4 3/4 chromo/teflon heim joints
    • 4- 16" FOX racing coilovers with dual rate kit.
    • 4- hummer H2 wheels with aluminum beadlock rings.
    • 4- 39.5/13.5/17 Iroks (brand new)
  • Willwood Dual Master/res brake kit with pedal assy.
  • Stainless flat dash with removable center section to get to battery tray which has been relocated inside the fir wall, under the dash.
  • 1- Cobra monaco racing seat, fixed back.
  • Jeep has a factory non-tilt column in it currently.
This is a non-finished project that was started in December of '05. Due to reasons beyond my control I am unable to finish in the time frame I would like to. I WILL NOT be selling any parts seperate, its an all or nothing deal! No trades, unless its something of equal value and in complete, running condition (farm animals do not count)
$6500
Any questions... contact me here: justinw@pspring.com
pictures and build progress can be seen here: http://www.misfitoffroad.com/phpbb/viewtopic.php?t=5308
XJeeper is offline   Reply With Quote
Old April 27th, 2006, 09:07 AM   #2
Strangler
Strangler's Avatar
Once again, sorry about your situation. This is going to be an awsome Jeep, and if any of you are even considering hacking up your daily drivers to create something similar you would be miles ahead to buy this one. Its really a top-notch build.
Old April 28th, 2006, 07:56 AM   #3
XJeeper
misfit
XJeeper's Avatar
Thanks Scott!
As I said, I dont want to sell this, and Im sure there are alot of friends that will be pissed at me for doing so.
Alos have lots of extras and misc parts for this project, everything will go with it.
Justin
Old April 28th, 2006, 08:11 PM   #4
trail junkie
Guest
Posts: n/a
What needs to be finished to make it run????
Old April 29th, 2006, 07:08 AM   #5
Hooperdog
OllllO
Hooperdog's Avatar
sits lttle low for off roading doesn't it? lol!
Sweet project how far is it from being drivable?
Hooperdog is offline   Reply With Quote
Old April 30th, 2006, 11:39 AM   #6
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
Crap Justin I was really looking forward to you finishing this.
I'd offer my Yota in trade, but I'm not thinking it's even close to enough, even with some $$ added in.
Hope you find some way that you don't have to sell it
nmeinc is offline   Reply With Quote
Old April 30th, 2006, 11:38 PM   #7
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
BAD ASS piece right there. bump for ya!
Old May 1st, 2006, 07:17 AM   #8
93yjsahara
hey Justin, I PM'd ya and sent ya an e-mail.
give me a call @ 313-475-0740
Steve
93yjsahara is offline   Reply With Quote
Old May 1st, 2006, 01:25 PM   #9
XJeeper
misfit
XJeeper's Avatar
Thanks for all the good words guys! Im currently talking with Steve about a possible sale, but the Jeep is still for sale.
karl, you dont wanta give up the yota anyway
Old May 1st, 2006, 01:34 PM   #10
XJeeper
misfit
XJeeper's Avatar
The jeep will need some type of steering, Ive set it up so far for a Hydro steering setup. Driveshafts will also be a needed item. after that, I supose exhaust and some of that most valuable stuff... time. most everything is there, it just needs put together and all the bugs worked out.
The entire thing is built for simplicity. there is nothing fancy about the build. the rear was dove tailed so the body/frame could be kept low, without the tires bashing the tub or the use of bum stops to limit up travel. Same thing goes for the fenderless front end. Did it a little different and just followed the lines of the hood. The cage is simple, but should be "multi-flipable" and IMO, it looks prettry damn good for a Jeep cage. The dash is plain and Id probably only have used one or two smaller guages for engine vitals.
Also, I made the door bars come in off the B pillar a little so Half doors will still fit, and it just so happens that I have a set. The windshield frame is there, but the glass is broken, Ive also got a brand new Bikini top for it that fits onto the winshield channel and follows the cage perfectly. A set of upper soft doors and the cab would be closed in, save for the back end... wich can also be modified off the 'X' to be enclosed.
Old May 2nd, 2006, 01:47 PM   #11
trail junkie
Guest
Posts: n/a
Look at my gallery pis and let me know if my cj interest ya.
Old May 2nd, 2006, 03:05 PM   #12
Mclovin
"The Situation"
Mclovin's Avatar
That seems like a preatty good price for all that, if only my tax return were bigger.. :grin: Are you located in fenton it seems like i recall u being from fenton for some reason..
Old May 3rd, 2006, 12:46 PM   #13
XJeeper
misfit
XJeeper's Avatar
I am from Fenton I moved to White Lake in December.
Deal Pending with 93YJsahara, Ill make it known what happens.
Old May 3rd, 2006, 07:40 PM   #14
93yjsahara
good bye YJ...and ZJ, hello...umm YJ
Old May 6th, 2006, 12:34 AM   #15
snocross2xtremes
snocross2xtremes's Avatar
i have cash in hand and would like to come take a look at this jeep on sunday... i sent u a email also
thanks joe
Old May 6th, 2006, 04:00 PM   #16
XJeeper
misfit
XJeeper's Avatar
Hey Joe, I sent a reply via email.
Justin
Old October 13th, 2006, 04:53 PM   #17
Blackbeast2
Hardcore since 84
I got wood
Blackbeast2 is offline   Reply With Quote
Old October 13th, 2006, 05:15 PM   #18
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Originally Posted by Blackbeast2
I got wood
why in the hell did you go back and dig this up?
I'm the man in White.
Old October 13th, 2006, 05:32 PM   #19
Mongo
Mongo's Avatar
He's working towards his 2000 post goal.
http://www.greatlakes4x4.com/showthread.php?t=23829
Mongo is offline   Reply With Quote
Old October 14th, 2006, 07:05 AM   #20
Strangler
Strangler's Avatar
this is for sale again. pm 93yjsahara
Page generated in 0.34362 seconds with 83 queries
