Turn signals.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2008, 06:08 PM   #1
gadgetman80
gadgetman80's Avatar
Default Turn signals....
I can't figure this one out, maybe I'm missing something......
When I turn my headlights on, the right flasher indicator is solid...always.
nothing changes when I switch the lever.
I can turn on my 4 way flashers and all works fine.
I swapped flashers in the fuse panel and I get the same results.
what am I missing?
gadgetman80 is offline   Reply With Quote
Old August 27th, 2008, 06:19 PM   #2
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Bulb
GNJEEPN is offline   Reply With Quote
Old August 27th, 2008, 06:21 PM   #3
gadgetman80
aren't the 4ways using the same filiament as the turn signals?
Old August 27th, 2008, 06:23 PM   #4
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
The fillament can break and touch the other fillement causing what you are describing.
Old August 27th, 2008, 06:26 PM   #5
gadgetman80
Hey, I'll check that out.
Doesn't make sense to me that all six flashers would work when the hazards are on(counting side markers)....but that's normal when stuff don't make sense.
thanks
Old August 27th, 2008, 06:27 PM   #6
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would suspect you have a bad bulb or socket. I would guess you have already pulled out all the old bulbs and installed new? if not thats the first thing to do.
start with the rear ones
Old August 27th, 2008, 06:30 PM   #7
gadgetman80
The rear ones are grommet mounted in the bumper. have to find some the same, prolly a truck stop or something.
Old August 27th, 2008, 08:39 PM   #8
mudd_jumper
mudd_jumper's Avatar
the round ones? you can get them any auto parts. yes start with bulbs my YJ did the same had a running light out.
Tags
no blinky blink
Page generated in 0.18528 seconds with 47 queries
