242 replacing a 249 ZJ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2008, 03:16 PM   #1
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Default 242 replacing a 249 ZJ?
just woundering what all i would have to do to switch out that famous 249 in favor of a 242 or the other transfer case i forgot what the other would fit right in>? i wanna have the option of 2wd and still keep my v8 so i need details and opionons
98ZJ318 is offline   Reply With Quote
Old August 26th, 2008, 01:26 PM   #2
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
nobody???
Old August 26th, 2008, 01:33 PM   #3
84Scrambler
Make sure you buy a 242 with the same length input shaft. There are 3 possible lengths that you could have. Or tear both cases apart and swap shafts from the 249 to the 242.
Old August 26th, 2008, 01:46 PM   #4
PavementPounder
PavementPounder's Avatar
Its a good, popular swap if you want to retain the option of the full-time 4wd and really not very complicated aside from the different input lengths. You just want to make sure the output shaft of the transmission does not bottom out in the 242's input and at the same time that it also has sufficient engagement and isn't sitting too shallow.
Allpro Automotive in Lansing (Junk90XJ here on GL) has done a number of them.
Old August 26th, 2008, 02:17 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Be careful, as there are two different pitches to the input gear. I think the change over is around '94, but I'm not 100% sure.
Old August 26th, 2008, 02:42 PM   #6
ajmorell
Pretty common swap. Check this out, it might help
http://www.jeepforum.com/forum/showthread.php?t=239528
http://jeephorizons.com/tech/tcase.html
Old August 26th, 2008, 02:44 PM   #7
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
all i have to do is swap out the transfer cases and the shafts and thats it? some1 told me ide prob have to swap out the axles?
Old August 26th, 2008, 02:55 PM   #8
84Scrambler
Have you been on JU talking to the 12 year olds again? Axle swap? WTF?
Old August 26th, 2008, 02:55 PM   #9
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
No, you don't.
*2007 Rubicon
*2006 Duramax
Old August 26th, 2008, 03:13 PM   #10
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
thats badass thanks for the links
Old August 26th, 2008, 07:06 PM   #11
Cooter
Cooter's Avatar
I would swap out the front axleshafts to the u-joint style, however.
Old August 26th, 2008, 08:34 PM   #12
PavementPounder
Cooter = Detective
Old August 26th, 2008, 08:36 PM   #13
Cooter
Cooter's Avatar
I was thinking he was considering "shafts" to mean driveshafts.
Page generated in 0.23981 seconds with 62 queries
