Intake FUBAR - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2008, 12:21 PM   #1
mudchucker
mudchucker's Avatar
Default Intake FUBAR
Hey guys, i recently hit a little bit of muddy water too fast and i have a cone K&N open filter which allowed all the crap to stick right to it. When i came home i found the muddy water had gone through the filter and all the way to the throttle body and i am sure beyond. Is there a way of cleaning this out? Can i shoot WD-40 down the entire intake until it looks clean and pull the plugs and just spit it out? any suggestions?
thanks,
mudchucker is offline   Reply With Quote
Old August 25th, 2008, 01:54 PM   #2
tweak
Are we there yet?
tweak's Avatar
Have you checked the oil to make sure that its not milky?
Old August 25th, 2008, 05:13 PM   #3
mudchucker
mudchucker's Avatar
Yes, the oil looks good and clean, not milky at all. I am not sure this is even a problem, but i don't want to take a chance. The stuff that made it through would have to be tiny because it made it through the fiter, so i am not sure how it would be any different than a little dust getting through from normal driving, other than it had a little water in with it, so now it is visible.
Old August 25th, 2008, 05:17 PM   #4
silverxj
Recovering XJ owner
silverxj's Avatar
I would probably just do a simple decarb/fuel injection cleaner through your throttle body, wash your filter, change the oil (safety measure) and buy a sock for your filter through summit.
No the sock will not stop dust, water or limit air flow, but it will help minimize it.
Old August 25th, 2008, 05:57 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I do not run a K&N for this reason. Paper is much better and filters more. I just put a K&N pre-filter foam around my intake that i oil the crap out of.
Old August 25th, 2008, 06:05 PM   #6
muddin_wolverine
muddin_wolverine's Avatar
i had alot of problems with water, bein that the only mud in my area is wet sand
i ran an air cleaner with a hose through the fire wall, works great!
muddin_wolverine is offline   Reply With Quote
Old August 25th, 2008, 06:50 PM   #7
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
x2. Buy a filter wrap to keep out sand and chunks of mud that hold water.
Page generated in 0.28341 seconds with 44 queries
