looking at a 89 ranger what do i look for? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2008, 11:12 AM   #1
skife
skife's Avatar
Default looking at a 89 ranger what do i look for?
clutch, brakes, alternator and fuelpump have all been replaced.
is there anything specific that goes wrong with these that i should look for?
Old August 25th, 2008, 12:54 PM   #2
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
2.9L or the 4 cylinder?
if its a 2.9 w/ high miles, check the valve cover gaskets for leakage, ive heard that happens alot.
Bronco351 is offline   Reply With Quote
Old August 25th, 2008, 01:28 PM   #3
88mudder
In the band!
check the body mounts make sure they arent rusting through..
check the floors for rust
if its the Automatic trans id say stop right there....the a4ld's are shit
Old August 25th, 2008, 02:29 PM   #4
skife
skife's Avatar
5 speed 2.9 v6
4wd extended cab short box.
150000 miles
Old August 25th, 2008, 02:31 PM   #5
88mudder
In the band!
if the engine dont have the lifter tick then go for it!
Old August 25th, 2008, 03:16 PM   #6
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
look at the back hatch area lift up the carpet at the back make sure its solid look at the rad support and if those are good i would say buy it
Bronco Ollie is offline   Reply With Quote
Old August 25th, 2008, 07:08 PM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
definatly check the cab mounts for rust
in addition check the shackles for rust as well
can't remember which 5sp those had, but if it's the mazda, check the fluid as the seals on drop are prone to leaking and causing failures
Old August 25th, 2008, 08:53 PM   #8
Bronco Ollie
the tranny will prolly be a fm-146
Old August 26th, 2008, 03:13 PM   #9
skife
skife's Avatar
i drove by it today and decided that its a little bit to rusty for me.
there is a peice probably 2"x4" rusted out from the fender.
Page generated in 0.24499 seconds with 50 queries
