np241 to np205 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2008, 06:14 PM   #1
hipburwig
hillbilly deluxe
hipburwig's Avatar
Default np241 to np205
have a 91 burbn 350 700r4 or 46le what ever they changed it to. i have an np241 and want to swap it out for the 205. any one ever swap one out or know what would be needed as far as brackets, hardware, fabrication?
hipburwig is offline   Reply With Quote
Old August 26th, 2008, 08:42 PM   #2
itsachevything
Jeeps make me itch
itsachevything's Avatar
i did a strait axel coversion on my 93 truck, and i made a adapter plate to run the 241 tail shaft housing on my 208. on a 241 the speedo hook up is in the tail shaft, so you have to change it over if you still want the speedo. if you ave a 4l60, you have to run a speedo or else the tranny will not shift out of first. i would not suggest running a 205 if it is a 4l60 because the case was not designed to carry that much weight. if it is a older style 700r4, then you might be safe. i would try to fing a 208. i also had to make a cross over linkage for the shifter to the transfercase. if you have a 700r4 i think you should still have a cable driven speedo that should connect into the 205. if you think you need the peices i was talking about email me because i make and sell them, kinda dont want to spill my secret, ha ha
rich @ yothers455@yahoo.com
itsachevything is offline   Reply With Quote
Page generated in 0.19842 seconds with 29 queries
