banshee trans fluid - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2008, 06:53 PM   #1
special k
special k's Avatar
Exclamation banshee trans fluid
does Bel Ray Gear saver 80w-90 transmission fluid sound correct for a banshee?
any input appreciated or if any one uses anything better let me know!
Old August 29th, 2008, 03:08 PM   #2
B
NINJA DEALER
B's Avatar
you can use that.. i use klotz flex drive 30 it's not cheap but it's the best. takes like 1.6qts
B is offline   Reply With Quote
Old September 3rd, 2008, 12:13 PM   #3
Cartman
Can't lose with 42s
Cartman's Avatar
Put the cheapest type F ATF you can find in there
Clutches will last waaaay longer and you can save some $$
I've done it for years on all of my drag bikes and trail bikes.
Cartman is offline   Reply With Quote
Old September 3rd, 2008, 12:31 PM   #4
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
if you use type f make sure you use 2 full quarts, and change it often!!!
I run type f in my drag bike and I use maxima mtl 80w in my play bike.
91 k1500 is offline   Reply With Quote
Old September 3rd, 2008, 12:41 PM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
I always used valvoline staight 50
Page generated in 0.17952 seconds with 38 queries
