89 CK1500 PU 4x4 New info 10-4-08 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2008, 05:39 PM   #1
mudd_jumper
mudd_jumper's Avatar
Default 89 CK1500 PU 4x4 New info 10-4-08
Ok some of you guys know from my other post that I got this given to me. I have all the issues settled up except one. This truck has sat for about 2 years.. It has a 4 bolt 350 tbi and it after it sits or has not run in a bit I need either to start it after that it runs great. It will start right up if you shut it off just will not start on its own after it sits. Any thoughts? I have replaced the fuel filter and check the flow while it was off. I had great solid flow. What else should I cheek?
Old August 24th, 2008, 05:48 PM   #2
farm_boy
hicktown
farm_boy's Avatar
vumucu psi nit whould do what you are saying check for leaks in line or checks dry rot
farm_boy is offline   Reply With Quote
Old August 24th, 2008, 05:51 PM   #3
mudd_jumper
could not find any fuel leaks checked for them or do you mean a vacuum leak?
Old August 24th, 2008, 05:54 PM   #4
farm_boy
hicktown
farm_boy's Avatar
yes a vucuum leak the egr and tbi sytems on this truck have to have vucuum to start my old truck had this
Old August 24th, 2008, 05:57 PM   #5
mudd_jumper
Thanks I will have to look for a vacuum diagram and look for leaks. Is there anything else it could be?
Old August 24th, 2008, 06:20 PM   #6
farm_boy
hicktown
farm_boy's Avatar
it also chold be in the tb but not sure how to check it
Old August 24th, 2008, 06:23 PM   #7
mudd_jumper
Me neither that is why I am asking Thanks for the places to start.
Old September 23rd, 2008, 09:12 PM   #8
mudd_jumper
Ok I can get it to start on its own. If I turn the key on I can hear the fuel pump kick in and run. If I do that a couple of times it starts runs a min then dies if I do that a couple of times it will run on its own. I am thinking fuel pump check valve or sucking air some were? what do you all think?
Old September 23rd, 2008, 10:09 PM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
Does it have 2 year old gas? Great solid flow on your fuel don't mean shit, make sure you have around 14psi I believe, pushing the valve on the fuel line isn't a sufficient way to check fuel pressure.
booblinker is online now   Reply With Quote
Old September 24th, 2008, 12:39 PM   #10
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
9-13 psi but closer to 13 the better
beaterk5 is offline   Reply With Quote
Old September 24th, 2008, 08:23 PM   #11
mudd_jumper
no it is new fuel.
I will have to put a gauge on it and see what the pressure is. I think I should do a leak down test to?
Old October 5th, 2008, 09:00 PM   #12
mudd_jumper
ok there is no place to check the pressure. When I pulled the line off there is a burst of fuel then nothing when I turn the key on. When it is up and running there is a good flow out the TBI. I am thinking that maybe the pump check valve is shot? I can here the pump cycle when the key is on. I am still having a pain of a time to figure out what is wrong. Maybe something in the choke mech.? Or a full tune up is the only things that I can think of?
Old October 6th, 2008, 10:13 PM   #13
mudd_jumper
Any one?
Old October 12th, 2008, 08:09 PM   #14
mudd_jumper
Angry I Am Stumped
Ok I finaly got it up and running. Butt...... It still does not like to start when it has sat for awhile and is cold. It still runs for a sec dies then can restart it and does it again and I can still do this a few times (10+) or so. The only code I get is # 12 the speed sensor. I have tested all the other sensors and they all test fine. I have tuned it up cap rotor and plugs. the only thing I can think of is a check valve in the pump? Timing is good new timing chain plug cap rotor fresh gas. I AM STUMPED any one????????
Old October 12th, 2008, 08:18 PM   #15
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
ok try this. after you have let it sit. open the gas cap before you start up. if by chance the tank vent is plugged you will have pulled a vacuum againest the whole fuel systam and the tank at that point becomes a huge vacuum ball. by popping the cap you break the vacuum. if by chance this does work check all the tank vent lines for mud dobber nests, they plug the crap out of little holes when things sit.
Yetti
Old October 12th, 2008, 08:29 PM   #16
mudd_jumper
Man what do they look like? LOL :P I will let it sit over night and try it when I get home from church tomorow night. I am willing to try just about anything to get it up and running! I need it to haul wood to start my new pile for next year. Oh yea and snowmobile season is coming soon!
Old October 14th, 2008, 12:08 AM   #17
kevinr839
kevinr839's Avatar
They make an adapter that goes in place of your fuel filter so you can check the fuel pressure
kevinr839 is offline   Reply With Quote
Old October 15th, 2008, 06:34 PM   #18
mudd_jumper
well that is what I get to go buy then Can I get this at any auto parts store?
Old October 16th, 2008, 05:40 PM   #19
mudd_jumper
I tried to find one and know one knows what I am talking about. Is this something I have to make myself?
Old October 17th, 2008, 09:10 PM   #20
mudd_jumper
ok I figured out how to make one. Will post result tomorow if I get to it...
Page generated in 0.62574 seconds with 83 queries
