JK Dana 44 vs Older Dana 44 axles - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 6th, 2010, 08:09 AM   #21
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Originally Posted by stk-snd View Post
Can you get me one for that price I want one Bad with a 4.56 gear.....email me at stksndtj@yahoo.com
I am sure he could 2 YEARS ago
Old December 23rd, 2010, 02:47 PM   #22
bigredjeep1
Originally Posted by Cooter View Post
The locking hubs don't really have anything to do with the axle strength, per se. I would say your downsides will be different bolt patterns, different widths, and having to hack off a lot of bracketry. I personally would run a pair of waggy axles and be done with it. The 8.8 likes to bend axleshafts, and adding 1" extra hanging off the end isn't going to help issues.
Keep in mind that for the JK or a HP D44, you would need to flip the D300.
I have waggy 44s in my 91' YJ with 5.38 gears and welded...cheap and strong and easily handle 35s! I don't see the point of paying all the $ for the WK "dana 44" only to add expensive custom manual hubs, take off all the bracketry...trying to match it up with a Ford 8.8 which isn't a bad axle but is narrower already at 58" and the JKs are around 64" WMS to WMS....
Id suggest going with waggy 44s or if don't mind it being wide get Ford HP44 and 9" axles for it.
I have those 2 setups in my YJs!
bigredjeep1 is offline   Reply With Quote
Old October 5th, 2011, 08:29 PM   #23
peg
Thinking of switching my high pinion 30 to 44, the problem I have is wheel bearings, the unit bearings are weak as hell. I think the new 44 still have the unit bearings. I only run 33's with 410 and a 4.0 and I have to replace them every year, can't seem to keep axle seals in tact once the outer bearing goes bad. fluid everywhere.
peg is offline   Reply With Quote
Page generated in 0.18638 seconds with 32 queries
