Aftermarket XJ 4Dr Fender Flares - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2008, 04:50 PM   #1
RAVC1
RAVC1's Avatar
Default Aftermarket XJ 4Dr Fender Flares
Need some help here.
I'm mounting 31x10.5R15 tires and will be using 1.5"-2" spacers for a total of 3.75"-3.25" of backspacing with the OE 15x7 rims. Hopefully lift will be 2"-2.5" as I'm trying to keep it low since the wife is short. Hence, I think this means I'll be trimming sheet metal. I'm okay with trimming but need input to know which flare will work with trimmed fenders. These things are blasted expensive so I only want to spend the cash once.
Anyone have experience with the BW Extend-a-Fender? The BW Pocket flare is too big for this tiny 31" tire. What about Rusty's flares?
Good advice & photos are welcome. Seeing what either of these look like on the 4Dr would help a lot. Most dealers do not stock them so you cannot see the flares before committing to purchasing them (BAD!).
Please note I'm working with a 1989 XJ and a 1997 XJ. I think BW only offers the Extend-a-Fender for the 1989 and not the 1997.
Thanks,
Rick
RAVC1 is offline   Reply With Quote
Old August 22nd, 2008, 06:03 PM   #2
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
You could just remount the stock ones after trimming a little bit, or if not much offroading will be done, I wouldn't bother trimming at all because the only time much rubbing will happen is when your articulating.
*2007 Rubicon
*2006 Duramax
Old August 22nd, 2008, 06:11 PM   #3
muddyjeep9
muddyjeep9's Avatar
or when your turning.
muddyjeep9 is offline   Reply With Quote
Old August 22nd, 2008, 06:16 PM   #4
OnlyInMyXJ22
No Money = No Fun
True...back when I had 30's on my XJ when it was stock I had no problems at all though unless I was articulating. If so you can trim the inside of the fender flare itself though.
*2007 Rubicon
*2006 Duramax
Old August 22nd, 2008, 11:23 PM   #5
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
pocket flairs rock
Old August 22nd, 2008, 11:52 PM   #6
Fraser
Fraser's Avatar
Originally Posted by unclebeaner View Post
pocket flairs rock
i prefer the rustys flares myself, but thats just me
Old August 23rd, 2008, 12:27 AM   #7
unclebeaner
but you also perfer men
Old August 23rd, 2008, 06:15 AM   #8
RAVC1
RAVC1's Avatar
Unclebeaner,
Need more pics or the ability to see your XJ in person to know how the BW pocket flares really look. My current opinion is they are too large. However, I do agree they can look fine with the right wheel and tire combination. My wife's '97 is the same color.
Yes, sheet metal needs to be trimmed even for 31's when you turn and flex the suspension. The next set of tires will be 32's so I need to think ahead. I may go to 33'3 but this would also require a new gear set; I have 4.10's now.
I would like to see the Rusty's flares before committing to purchase anything. Some folks have done some creative work to retain the OE flares with larger wheels on NAXJA. 53guy is one example and he had an excellent write-up. I have his pdf's and I'll use these as reference material to help me make my decision.
Thanks,
Rick
Old August 23rd, 2008, 10:14 AM   #9
Fraser
Fraser's Avatar
Old August 26th, 2008, 10:47 PM   #10
Immortal
NO RELIGION WAT!
Immortal's Avatar
Here is a close up of the rear
Old August 26th, 2008, 10:54 PM   #11
unclebeaner
oooooooo i want those rims.....................
if you need to look at ti let me know
Old August 27th, 2008, 08:00 AM   #12
jeepxj_boy_21
linked
jeepxj_boy_21's Avatar
jeepxj_boy_21 is offline   Reply With Quote
Page generated in 0.31081 seconds with 59 queries
