Where is an engineer when you need one? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2008, 10:28 PM   #1
MiNi Beast
MiNi Beast's Avatar
Question Where is an engineer when you need one?
Can I build my cage without a tube bender?
Thinking of using 1.75 x .120 wall and want to start building my cage here soon but need to know if I could just make angled cuts on the tubing to make the cage come together, speaking in terms of the A and B pillers (my main hoop),
if it would be strong enough I guess. The welding skills are top notch and which mean it will not be done by me, so I trust the welds, just been researching cages and trying to find the engineering details I need to know.
thanks
Old August 21st, 2008, 08:07 AM   #2
Tab
Tab's Avatar
If your paying to have have something welded (or even a favor) you can have someone do the bends for you. Usually they would only be a few bucks a bend or find someone here that will hook you up. You could do a cage like that but you would have to gusset the shit out of it and it would be the dumbest looking thing you've ever seen. Plus the laughing stock of the intraweb. But I'm no engineer.
Old August 21st, 2008, 08:12 AM   #3
95geo
newbie
95geo's Avatar
I'm no engineer, and you dont have to be to know that a completely mitered cage is retarded.
remember- just because you can doesnt mean you should.
pay someone with the proper tools and knowledge to build a cage.... I mean, hell, it's only your life we're talking about...... you might as well make a mitered cage out of muffler tubing so it doesnt weigh much.
Old August 21st, 2008, 08:21 AM   #4
CreativeFab
used to be Ironman
CreativeFab's Avatar
If you would like to rent a bender get ahold of me.
A security deposit would required!
Old August 21st, 2008, 08:27 AM   #5
VTJeepCJ84
Send a message via AIM to VTJeepCJ84 Send a message via Skype™ to VTJeepCJ84
For a normal trail cage I would say find someone with a bender you can buy a case of beer for and have them put some bends in for you.
That being said, if done correctly a very fuctional cage can be built with all mitered joints.
Here's and example, I think there are 4 bends total:
http://www.race-dezert.com/forum/att...1&d=1194310124
Here's the whole thread on that build, it's really long, but the guy does amazing work.
http://www.race-dezert.com/forum/showthread.php?t=31417
VTJeepCJ84 is offline   Reply With Quote
Old August 21st, 2008, 08:33 AM   #6
Flexin' XJ
Flexin' XJ's Avatar
Fake. It is too clean of a workshop.
Flexin' XJ is offline   Reply With Quote
Old August 21st, 2008, 08:44 AM   #7
These 2 posts pretty much say it all. Can you? Yes.... Should you? No
Old August 21st, 2008, 08:45 AM   #8
95geo
newbie
95geo's Avatar
there is more work into one joint on that truck then most people put into a whole cage. That whole truck has been designed on the computer and every tube has been cnc laser notched.
hardley a comparison but yes, that is an example.
Old August 21st, 2008, 09:01 AM   #9
Bones
Bones's Avatar
He also has to use a TON of more tube to build a chassis with all mitre cuts compared to a chassis of the same strenth/size with bends.
you could put a full jungle gym on your rig with double triangulation and truss support on every corner.... or you could just bend a tube.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 21st, 2008, 04:55 PM   #10
clint357
Web Wheeler Extraordinair
clint357's Avatar
Square/mitered would look gay, but it's actually stronger. Just like how square tube is stronger than round.
clint357 is offline   Reply With Quote
Old August 21st, 2008, 09:10 PM   #11
MiNi Beast
MiNi Beast's Avatar
Well I was thinking of going with the 10 pt set up from SWracing then just adding some dom to it for my own set up then this way I could have a basic set up with all the bends in it for me to install.
Old August 22nd, 2008, 08:12 AM   #12
95geo
newbie
95geo's Avatar
post a pic or a link to the cage you're talking about..... this is different than what you have in the first post. pretty much all of the additional bars to the cage are straight, usually just the ones that give it the main appearance and perimeter are the ones with bends in them.
a nice simple but strong cage can be built with only 6-8 bends.
Old August 22nd, 2008, 08:58 AM   #13
Bones
Bones's Avatar
disagree, with a given lenth of tube, you could builde a MUCH stronger chassis with bends than a chassis with just miters.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 22nd, 2008, 09:05 AM   #14
1badzuk
1badzuk's Avatar
i have a bender so just bring me the 50 ya owe me and some beer and we can do it up you know where i live.
1badzuk is offline   Reply With Quote
Old August 22nd, 2008, 11:06 AM   #15
clint357
clint357's Avatar
I didn't mention anything about tube length used.
Old August 22nd, 2008, 11:34 AM   #16
95geo
newbie
95geo's Avatar
Sure, if you use 600' of tube in a mitered cage with a node point every 12-18" it'll be a whole shit ton of a lot stronger than a properly bent cage that uses 200' of tube and has a node point every 24-36"
Why dont you build a square tube mitered corner cage since it is a superior design?
Old August 22nd, 2008, 12:12 PM   #17
Bones
Bones's Avatar
then you're right, if you use 6 times the amount of tube, you can have an awesome mitered cage.
If you use 10x the weight in concrete and rebar, you can probably have a sweet cage too
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 22nd, 2008, 03:02 PM   #18
FlatFender
Tap Tap Splat
FlatFender's Avatar
I want to live in a world where concrete and rebar cages are the norm.
Old August 26th, 2008, 04:44 AM   #19
clint357
clint357's Avatar
I thought you were talking about the 5% more tube you use when doing miters. What I am saying is that a 90 degree miter is stronger than a 90 degree bend, that's all.
Old August 26th, 2008, 05:48 AM   #20
muddin_wolverine
muddin_wolverine's Avatar
AND most people build a cage to save their life if they roll, those trucks are built to fly, land, crash, roll, AND finish the race
so shame on you for wanting to try and build something on your own with a little help from others. pay someone to do it, cause thats the cool thing to do :)
mitered cages can look bad ass if you put some thought into it, and stronger joints=less cage, and less cage=less weight, EVEN if the joints weight more...
but im an engineer, and we dont know shit :)
muddin_wolverine is offline   Reply With Quote
Page generated in 0.43180 seconds with 83 queries
