supercharged 1967 Camaro for sale - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2008, 09:00 PM   #1
darkostoj
I have parts
darkostoj's Avatar
Send a message via AIM to darkostoj
Default supercharged 1967 Camaro for sale
This is a 1967 Camaro. It has a 350 4 bolt main motor with world sportsman heads (2.02/1.6 valves and 200cc intake ports), larger cam, long tube headers with 02 bungs welded in for an 02 sensor, weiand 671 supercharger blower kit with dual edelbrock 600 cfm carbs. Carbs have been modded with larger jets/metering rods, larger fuel discharge nozzles, and high flow needles/seats, enderle roller throttle linkage, and have a polished aluminum carb bonnet. There is a mallory unilite distributor which has been recurved for the blower, 8mm spark plug wires, and an accel high volt super coil. It has Holley electric pump with holley regulator, extra electric pusher fan, autometer fuel and boost gauges. Black interior is in very good shape, original center console car, SFI 6" harmonic balancer, 3.73 rear gear with a posi carrier, subframe connectors, traction bars, air shocks, Borg Warner aluminum case Super t-10 trans out of a corvette(one of GM's strongest manual transmissions) with a hurst shifter (the shifter could use some adjustment, and there is some clutch chatter when taking off in 1st gear). The car was restored and had the rear quarters, rockers, and taillight panel replaced, but it was good work done by a body shop and has no rust now except for a little bubbling in the front lower corners of the doors, but its not through the paint. The car is not perfect and could use some fine tuning on the carbs, but I drive it everyday(motor always fires instantly and has been reliable for me), turns lots of heads, and gets more attention than any muscle car I've ever owned.
video
http://www.youtube.com/watch?v=IB2sgs_1JpY
$16,000
darkostoj is offline   Reply With Quote
Old August 19th, 2008, 09:16 PM   #2
Mopar_Guy
Mopar_Guy's Avatar
Bad Ass
good luck
Mopar_Guy is offline   Reply With Quote
Old August 19th, 2008, 09:17 PM   #3
newdodge
jeep life
newdodge's Avatar
bump for you one bad ass car
newdodge is offline   Reply With Quote
Old August 19th, 2008, 09:21 PM   #4
BigTony
Rock Rebel
BigTony's Avatar
I got wood.
BigTony is offline   Reply With Quote
Old August 24th, 2008, 09:00 PM   #5
b jeepin
Back in the game
b jeepin's Avatar
Default x2
Originally Posted by BigTony View Post
I got wood.
boyoyoying!
b jeepin is offline   Reply With Quote
Old August 24th, 2008, 09:12 PM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
Nice
Page generated in 0.32204 seconds with 41 queries
