Need Some More Braking power? - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old August 18th, 2008, 07:18 AM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Need Some More Braking power?
Have you switched to 4 wheel disc brakes and are no having trouble stopping? or you just want some more oomph?
An Easy, Cheap upgrade is to use the Master cylinder our of a 1985 Ford E350, 1 ton Econoline Van.
This is a readily available for about $30.00 at almost any auto parts store.
It is ALMOST bolt-in. There are 3 modification needed.
1) you will need adapters to your hard lines from the master cylinder outputs, small little brass things they were $0.71 each at my local Napa.
2) the bolt holes need to be enlarged slightly, they are just slightly off, a 1/2" drill bit can be used to elongate the holes.
3) the "ears" on the mounting flange are a touch to big to fit into the brake booster, i spent 45 seconds with a Grinder and flap wheel and it slid on like butter.
The Install:
Once you have made the modifications above is very straight forward.
Bench bleed new master cylinder
drain old brake fluid from old master cylinder
unbolt the 2 lines coming out of it
unbolt the bolts holding it in place
remove
place new master cylinder on and bolt it down
re-attach the 2 hard lines
Bleed the system
You should be ready to go (and stop) now
I did this on a 1995 YJ that originally had the 2.5L I believe this will work on MOST CJ's, YJ's and TJ's with vacuum brake boosters.
Old October 6th, 2008, 01:53 PM   #2
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
I did this with a grand Marq master Cyl.
Old October 6th, 2008, 02:24 PM   #3
Whats the bore size on it? (I'll be running different calipers than most, so I need to figure out some hydraulic ratios...)
Old October 6th, 2008, 02:28 PM   #4
oz97tj
Wasn't this attached?
oz97tj's Avatar
wow, that's cool.
Thanks for the info!
********GLFWDA.org********
Old October 6th, 2008, 02:29 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
1.125"
Old October 6th, 2008, 02:31 PM   #6
badazzamc
Get Some
badazzamc's Avatar
thats good to know
Page generated in 0.19676 seconds with 41 queries
