stupid ???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2006, 07:00 PM   #1
biggs-cj
biggs-cj's Avatar
Default stupid ????
well got a 351 m that doesent like to run anymore? it idles fine but when you give it gas it likes to back fire out the tail pipe and the carb.....checked the timeing, plugs ,wireing,and checked for air leaks around the carb ,nothing seems to be wrong,,,,,its got me baffled???????????anyone got something i missed????????
biggs-cj is offline   Reply With Quote
Old April 25th, 2006, 08:04 PM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
if it's backfiring like that it has to either be timing or a sticky valve. Double check the firing order just to be sure.
Old April 25th, 2006, 08:14 PM   #3
bigblue2230
still goin
bigblue2230's Avatar
does it have any aftermarket parts on it? I had a 351m in my trucvk before with a crane cam in it, and the new cam walked forward and chewed up the distributer gear, which made it run like crap and finally die. just something worth checking.
bigblue2230 is offline   Reply With Quote
Old April 25th, 2006, 09:13 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well if it helps to know I used to be a engine repair guy at the dealer. the back firing could be a couple of things. if its a stuck valve or bad guide then it will pop with every cycle of the ignition, as the engine speeds up the pop would speed up. if its a cam problem or a junk lifter it would build up and then go wild poping very fast at medium to high rpms. hope you get it sorted out.
Yetti
Old April 26th, 2006, 07:41 AM   #5
biggs-cj
biggs-cj's Avatar
thats the only thing i havent checked,its been sitting for a couple years,so it probly is sticky valves......it ran great before,donsent back fire at idle onle when you give it more gas,,,,have to check this out ....thanks
Old April 26th, 2006, 12:35 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Check your carb setting, Could just be you have the high RPM needle too rich.. I dont know much about carbs but i beleive they have a high RPM needle and a Low one
Old April 26th, 2006, 04:49 PM   #7
SageJp
SageJp's Avatar
If I had to guess, I'd say it sounds like a stretch out timing chain.
I've had 2 engines with stretched timing chains and both ran the way yours is.
SageJp is offline   Reply With Quote
Old April 26th, 2006, 05:46 PM   #8
biggs-cj
biggs-cj's Avatar
i was thinking that today.......going to check it out this weekend....do for a new one anyways
Old April 26th, 2006, 05:48 PM   #9
biggs-cj
biggs-cj's Avatar
?they have a air and fuel mixture but never herd of a high an low needle valve???thanks though
Old May 29th, 2006, 10:03 AM   #10
DeltaCavXJ
BCT made me hate Oreos!
Default dang
my olds is doing the same thing i think its a sticky valve but im not sure either
DeltaCavXJ is offline   Reply With Quote
Page generated in 0.19216 seconds with 53 queries
