how many kicks? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2008, 01:31 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default how many kicks?
91 CR250, how many times should I kick it over to do a compression test?
Old August 17th, 2008, 01:37 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
2-4 will give you all the compression it will ever build. Make sure you hold the throttle wide open while testing to make sure it can get all the air it will need in order to make the test accurate as possible
Old August 17th, 2008, 01:41 PM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
Guess I will retry it. I kicked it til it stopped rising and it went up to like 120, but that was like 10 kicks.
Old August 18th, 2008, 06:49 AM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
That's fine. Keep doing it until it stops - 10 kicks doesn't sound out of the ordinary.
120 psi.... that's low.
@clarkstoncracker
Old August 19th, 2008, 01:41 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yea I know Guess thats what 2 days at silver does.
Old August 19th, 2008, 02:15 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Before you do that again, I can tell you how to make it survive.
@clarkstoncracker
Old August 19th, 2008, 02:38 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
How? other then rejet for constant wot.
Old August 19th, 2008, 07:11 PM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You can go to a different taper needle that will give you similar part-throttle characteristics, but will add fuel closer to WOT.
I just need to know what needle is in your carb right now.
@clarkstoncracker
Page generated in 0.35818 seconds with 47 queries
