2 ton shit missle *UPDATED ON 8/8/09* - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2012, 08:17 PM   #201
2fst4you
2fst4you's Avatar
Originally Posted by Tab View Post
Back half is stock, added a complete front section and spreaders. The front is also tied into the frame. I've had the steel a couple different times to redo the entire cage but always used it for other (paying) projects. Also want to do new seats and cage at the same time.
O ok because the places you go the front better be strong
That would be nice I need to start with a cage! What size joints and bolts does everyone use for their upper and lower control arms when linking it?
Old November 26th, 2012, 05:38 PM   #202
Tab
Tab's Avatar
Johnny joints and 1.75x.375 wall DOM. I have one inch shank joints and if I was to do it again I would get the inch and a quarter. I've never broke one but have bent a few shanks.
Old November 26th, 2012, 05:43 PM   #203
2fst4you
2fst4you's Avatar
Ok thought so. Ya im thinking I want to do 1" shanks on the uppers and 1.25" lowers when I link mine
Old November 26th, 2012, 05:57 PM   #204
boggin-machine
boggin-machine's Avatar
do them all the same so you only need to carry one spare joint and not 2
Old November 26th, 2012, 06:04 PM   #205
Tab
Tab's Avatar
My four lowers and my one front upper are all the same material and length. My rear uppers are 1.5x.25 wall DOM with 3/4 rod ends.
Old November 26th, 2012, 06:08 PM   #206
2fst4you
2fst4you's Avatar
Good point but the uppers wont see as much stress will they?
Old November 26th, 2012, 06:30 PM   #207
Tab
Tab's Avatar
The front one does because its a three link. The rears no. And I'm sure it's overkill on the front even since it doesn't see the impacts the lowers do.
Old November 26th, 2012, 06:45 PM   #208
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If you only have one size joint you only need 1 spare. Just something to think about.
Sent from my PG86100 using Tapatalk 2
Old November 26th, 2012, 07:09 PM   #209
2fst4you
2fst4you's Avatar
That's what I was thinking.
Ya I understand that and its good thinking thanks
Old November 26th, 2012, 07:15 PM   #210
I bent one of my rear uppers on my very first outing after my build. I got a rock jammed up inside and carried whole weight of the jeep on it.
My next upper links will be the same material as my lowers. I'm tired of repairs where I can avoid it.
Old November 26th, 2012, 07:20 PM   #211
2fst4you
2fst4you's Avatar
Now I see how they can get bent
Page generated in 0.28268 seconds with 56 queries
