2 ton shit missle *UPDATED ON 8/8/09* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2008, 01:11 PM   #1
Tab
Tab's Avatar
Default 2 ton shit missle *UPDATED ON 8/8/09*
This is my build over the last few months with the majority of the work being done over the last month. I was working so long and so fast I rarely stopped for pics but if theres something you would like to see let me know, within reason of course. I started by selling a stripping most of the drivetrain out and cutting off the rear portion of the frame to move it inboard the tub for coilover room.
Heres the rundown.
'86 HP 60 narrowed to 67" with detroit locker and 5.13 gears
'99 14b came out to 65" with welded carrier and 5.13 gears
switched from nv3550 to aw4 from 2000 xj
tera low 231 4.1
fox coilovers 14" front, 12" rear
psc full hydro steering
1.75x.375 dom lower links (and the one front upper)
all lowers and the one upper are same length and I have one complete spare with ends.
Ends are Johnny joints
The rear uppers and track bar are 1.5x.25 dom and use 3/4 rod ends (as does the steering) so I only need one size spare.
Fuel cell is 15.5 gallons and is recessed into the floor 3.5 inches and the rest hangs down but not bellow the rear bumper.
3 link front 4 link rear
recentered H1 wheels and 39.5 TSL's
Only a couple of inches of shaft showing on the coilovers (4-6) but at the tires I have about 5-8 to the wheelwells.
stretched the wheelbase 11-12 inches. 8 in the front and 3-4 in the rear (I never remeasured after getting the axle installed and at ride height)
still have to do:
Clock t case a few inches and re-do the mount.
Build skidplates
Build front fenders
Build new rocker quards
Build rear corners
Build front bumper/winch mount
Work out bugs if any
Drives great, took it to the dunes last weekend and the suspension worked great but my coil wasnt getting the correct voltage so it ran terrible. I found a bad connection where i tapped into the factory harness for the new auto. Re-diod that and it drive excellent now. I still need to adjust the shocks slightly too but we'll see how ostc goes. Heres some pics. Fire away
Before
After
Old August 17th, 2008, 01:21 PM   #2
Tab
Tab's Avatar
More
Full stuff while mocked up.
A look at the lower and upper link mount, frame end.
Flexed out a bit, checking for issues.
Old August 17th, 2008, 01:33 PM   #3
Tab
Tab's Avatar
Ram mount. I didnt really like the idea of just using a single piece of tube across the front and the other version I've seen is a big piece made from 1/4 plate and box in at the same location I made mine. I went with my own idea and think its a better approach as it can incorporate a skid and does not hang lower than the axle tube. Cut from two pieces of 3/8 and welded all around. This still allows me to get into my diff if need be and the center hole on the skid is for my winch hook if I feel the need to suck down for a climb.
Finished front.
Lower link and shock mount.
Starting my fuel cell. Again, I didnt want to lose clearance in the back so I recessed it into the tub and was able to use the factory pump (with needed regulator) and I now use an RCI fill tube. I'll get a better finished pic soon.
Old August 17th, 2008, 01:43 PM   #4
Tab
Tab's Avatar
Shock mounts. I have better pics in progress but they are on the other camera so they will have to wait.
Rear
Rear bumper/end of new frame. Yes they are welded all the way through I didnt really want the normal rectangle tube with angled ends so I made this. I like it, it gave me the groung clearance and departure angle I was after.
Its not bent like the pic turned out
Shaved 14b and new disc brakes.
New wiring harness I made for the AW4 to go into a wrangler. Wasnt nearly as bad as I thought it would be and it works great so far.
Thats all for now. Sorry I did take better during pics but if someone wants to see something let me know.
Old August 17th, 2008, 01:50 PM   #5
ricmitch
ricmitch's Avatar
Default looks good
nice rig! nice job!
ricmitch is offline   Reply With Quote
Old August 17th, 2008, 01:56 PM   #6
IPLUMB
IPLUMB's Avatar
Love that rear bumper..Nice rig.
IPLUMB is offline   Reply With Quote
Old August 17th, 2008, 05:13 PM   #7
MozMan68
Poseur Extraordinaire
MozMan68's Avatar
I don't think it's hardkor enough......
MozMan68 is offline   Reply With Quote
Old August 17th, 2008, 05:18 PM   #8
silverxj
Recovering XJ owner
silverxj's Avatar
Your welds are sexy.
Old August 17th, 2008, 05:19 PM   #9
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Seen ya at silver looking sweet
Old August 17th, 2008, 05:22 PM   #10
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Nice!!!
*2007 Rubicon
*2006 Duramax
Old August 17th, 2008, 05:29 PM   #11
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Welds look like shit, next time call JP Fab. LOL
Looks good my shorts are tighter now.
Old August 17th, 2008, 05:41 PM   #12
kickstand
circling the drain
kickstand's Avatar
Tab every bit of that looks like shit.....I suggest you start over.
I like it :)
Old August 17th, 2008, 06:05 PM   #13
I'm jealous.
Old August 17th, 2008, 06:12 PM   #14
Tab
Tab's Avatar
I'm jealous.
why, I heard you were rippin' shit up in Canada
Old August 17th, 2008, 07:16 PM   #15
itchy
itchy's Avatar
Very nice build! Looks great.
itchy is offline   Reply With Quote
Old August 17th, 2008, 07:25 PM   #16
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
that rear bumper is fawking HOTT!
dont be mad if i copy it one day
Trailrig is offline   Reply With Quote
Old August 17th, 2008, 07:59 PM   #17
bk87
looking good
bk87 is offline   Reply With Quote
Old August 17th, 2008, 08:13 PM   #18
95geo
newbie
95geo's Avatar
Impressive Tab! nice work.
Old August 17th, 2008, 08:15 PM   #19
clarkstoncracker
lol
clarkstoncracker's Avatar
Looks ok, if you need me to clean up those welds, pm me.
Old August 17th, 2008, 08:27 PM   #20
deuce228
Redneck Poser
deuce228's Avatar
Whats with the True North?
Page generated in 0.37445 seconds with 83 queries
