LED rock lights - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2008, 01:29 AM   #1
clint357
Web Wheeler Extraordinair
clint357's Avatar
Default LED rock lights
So, I've been interested in doing this for a long time and I finally got some stuff together. Here is a shot at my first "real deal" rock light. It puts out 168 lumens (a little brighter than the standard XJ reverse lights I think) and only consumes 3 watts. The housing is aluminum and it is water tight and pretty much indestructable. You need a $20 unit to convert the power to run up to 6 of them. I'll post more pics up soon. I'm going to set up a website soon and see if I can sell some of these things for about $15-$20 each. The only other place that sells anything like this right now is roundeyes, but theirs are not nearly as bright as these. I'm also making 2 more mounting options as well. Let me know what you think. I can get them in different colors as well and controlers that have dimming and strobe effects too.
Side view
control unit with wiring harness and dimmer
Flush mount to be mounted on the back side (of a bumper or rocker or whatever) with a 1/2" hole drilled for the light to pass through.
I tried to get the exposure on these close to what it looked like to me
3' from the door
8' from the door (this one looks a little dim on the computer)
clint357 is offline   Reply With Quote
Old August 17th, 2008, 01:31 AM   #2
oz97tj
Wasn't this attached?
oz97tj's Avatar
those look pretty cool. I may be interested in some...
********GLFWDA.org********
Old August 17th, 2008, 01:38 AM   #3
clint357
clint357's Avatar
$15 each for anyone on GL4x4 and $20 for anyone else is what I'm thinking. I'd like to see what some colored ones look like on a nice bike too.
Old August 17th, 2008, 01:45 AM   #4
oz97tj
oz97tj's Avatar
I'd like to see a couple more pics. I may be in for a couple for the jeep. I have the bike too(in my avatar). I have a bunch of red leds I've been meaning to put under my fairings to make it glow red. I would bet I'd have to put a bunch on though to get a uniform glow. leds are just to direct in the direction the light goes.
on that same note, how much of an area do they light up, or would a guy need like 10 under the jeep? Also, your first post says you need a $20 unit to control them. So that is on top of the 15 a piece?
Old August 17th, 2008, 01:47 AM   #5
muddin_wolverine
muddin_wolverine's Avatar
what do they run on?
muddin_wolverine is offline   Reply With Quote
Old August 17th, 2008, 08:19 AM   #6
clint357
clint357's Avatar
They run on 3.7v and draw 1 amp, so you need an led driver to give them the right current from you battery.
Old August 17th, 2008, 08:22 AM   #7
clint357
clint357's Avatar
Yeah, the unit will run 6 of these lights max. As for brightness, I'll get some pics tonight.
Old August 17th, 2008, 09:08 AM   #8
clint357
clint357's Avatar
Also, I would suggest buying one of them and powering it with 2 aa batteries. This will give you a good idea of how many you will want. If you decide that you don't want to buy any, just let me know and I'll give you a full refund.
Old August 17th, 2008, 09:16 AM   #9
Tab
Tab's Avatar
turned out great! I will be in for some for sure. How big is the converter box and do you have a source for them? I'm glad to see they got to you by the weekend too.
Old August 17th, 2008, 10:01 AM   #10
clint357
clint357's Avatar
Here's the driver http://www.luxeonstar.com/buckpuck-1...-mount-p-7.php and you also need a $5 wiring harness. It's very very small (0.78x 0.78x 0.43 and weighs just 0.3oz) so you'll be able to put it anywhere. PM me if you want some.
Old August 17th, 2008, 10:34 AM   #11
hotwired
First time I've ever heard of a driver. Most people just use a resistor. There are resitor calculators on the net that let you input the source voltage, led voltage, current wanted through each LED, how many in the circuit, and are they parallel or series. A LOT cheaper than running a driver, that way you just need a switch to run them, and a resistor for each circuit. Back when I did my Nylint (remember them?) I also found some cicuit board mount led's that had a 105 degree angle/
hotwired is offline   Reply With Quote
Old August 17th, 2008, 11:16 AM   #12
clint357
clint357's Avatar
leds are very sensative to voltage, so if you have 12-14v input there is a fluctuation that could burn out the diode. this driver is more efficient too, and has overload protection. General Lee can fill you in more.
Old August 17th, 2008, 11:31 AM   #13
FlatFender
Tap Tap Splat
FlatFender's Avatar
What LEDs are you using? Luxeons? Ive not seen anything that puts out that many lumens on only 1000ma
Old August 17th, 2008, 02:02 PM   #14
clint357
clint357's Avatar
Cree 7090 3W Q4 LEDs. For about 5 dollars more, you can get 228 lumens, and in a while I'm going to play with their 12w 900 lumen diode. That's as bright as a 35w hella h3 bulb, but draws 1/3 the power and lasts 50 times as long.
Old August 17th, 2008, 10:11 PM   #15
clint357
clint357's Avatar
updated pics on first post
Old August 17th, 2008, 10:18 PM   #16
muddin_wolverine
those are pretty good! ill def get a few when i get home.
Old August 17th, 2008, 10:48 PM   #17
BigTony
Rock Rebel
BigTony's Avatar
Cool. How much are the 12w bulbs?
BigTony is offline   Reply With Quote
Old August 18th, 2008, 02:42 AM   #18
oz97tj
oz97tj's Avatar
ok, those are cool. When can a guy purchase some?
Old August 18th, 2008, 05:40 AM   #19
clint357
clint357's Avatar
Those will be about $35 each, but I still have to play with those to see how much heat sink they need. Those will each need a driver as well unless someone comes out with a bigger driver. I'll let you know when I get one of those designs made though.
Old August 18th, 2008, 09:49 AM   #20
CreativeFab
used to be Ironman
CreativeFab's Avatar
Clint, you coming to OSTC? Would like to see them on at night under a rig
Page generated in 0.35862 seconds with 83 queries
