Carbon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2008, 04:45 PM   #1
bigblue2230
still goin
bigblue2230's Avatar
Default Carbon
How much carbon buildup is considered normal. I just pulled apart the top end of my 2000 cr250 (I bought it back in January, so this is the first time I have pulled the top end on it) and there seems to be a lot of carbon. It also made the power valve very sticky. I went through it and cleaned everything, and the powervalve moves freely now. I put roughly 45 hours on this bike since I bought it, and the previous owner said he put less than 10 since a full rebuild.
Is this normal? Should I be rebulding this more often, or at least pulling it apart to clean these items?
I usually run 40:1 fuel/oil ratio.
bigblue2230 is offline   Reply With Quote
Old August 16th, 2008, 08:35 PM   #2
jeepguy74
jeepguy74's Avatar
what oil do you run i have had great luck with belray and klotz beanoil and have had minimal carbon and i ran the bike a couple years between rebuilds ...however the power valve gumms up from oils that arent designed for powervalves ( the 2 oils i just talked about are for powervalve motors) also klotz r50 (i believe) a buddy of mine used and had no problems with it.......
Old August 18th, 2008, 06:53 AM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
x2 on the oil brand. Oil is a science these days in a 2 stroke. Depending on how you ride, R50 might work well. It has a high film strength (like the old castor bean oils) without gumming up your PV. In my 300, it is bad because I don't ride on the pipe hardly ever. R50 caused me a few problems with fouling and spooge.
I recently changed over to amsoil premix and have had good results. Also, I run 50:1 in my bike.
@clarkstoncracker
Old August 18th, 2008, 07:42 AM   #4
bigblue2230
still goin
Ok, I was definately not running the right oil (I used to run an 84 rm250, and ran the same oil as that. DOH!) I was probably running too rich a mixture too. I will try better oil and less of it this next time around. Thanks for the input.
Old August 18th, 2008, 08:25 AM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Golden Spectro? That's what I used to run in my old non-pv bikes.
@clarkstoncracker
Old August 18th, 2008, 09:36 AM   #6
jeepguy74
jeepguy74's Avatar
i would stick with the belray ....you can get it at most bike shops and the dunes also and mixing ix easy one bottle to a 5 gal can of gas
which is like 40 to 1
Page generated in 0.27007 seconds with 41 queries
