How safe do you think this is? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2008, 02:57 PM   #1
TBSdontstop
TBSdontstop's Avatar
Default How safe do you think this is?
How safe do you think the front setup on my Blazer is? Mind you I didnt do I got the truck this way and I'm thinking that I'm gonna pull them all out.
Heres the rear setup witch is getting changed.
TBSdontstop is offline   Reply With Quote
Old August 14th, 2008, 03:00 PM   #2
howell_jeep
Last Free Man
howell_jeep's Avatar
You need to add some more, then you'll be able to go to silver lake.
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old August 14th, 2008, 03:39 PM   #3
PavementPounder
PavementPounder's Avatar
I wish I could see these pics from work.
Old August 14th, 2008, 03:45 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Almost scary just looking at it..........
I'd say lose the front and rear blocks and reverse the rear shackle on the rear diff to gain 4". If you don't care about the ride, you can always stack springs.
Old August 14th, 2008, 03:54 PM   #5
CreativeFab
used to be Ironman
CreativeFab's Avatar
Front lift blocks are illegal in MI, rear lift blocks cant be any more than 4"
Do what jbsjunk said about reversing the rear spring hanger, then buy appropriate front springs to match the rear lift. Do it safely so you can see next Christmas, becuase Christmas is fun!
Old August 14th, 2008, 05:47 PM   #6
PavementPounder
You could also replace the font perches with a set that is a little taller overall to make up the difference from removing the blocks. That would allow you to improve your pinion angle if needed, but you may create a caster situation.
Old August 14th, 2008, 05:59 PM   #7
Sandals
Fucking Zen as Shit
Sandals's Avatar
Remove the blocks!!!!
you also need at least 6 steering stabilizers to be teh cool
Old August 14th, 2008, 08:24 PM   #8
nd4spd71 might have some front 4" springs, send him a pm.
Old August 14th, 2008, 09:26 PM   #9
TBSdontstop
Right now I'm looking for 4" rear springs. My fronts are 4" lift right now from what I can tell but the rear are stock with maybe a add a leaf.
Old August 17th, 2008, 06:44 PM   #10
merr6267
More boost than yours:)
merr6267's Avatar
The block on the knuckle looks the worst in my opinion . . .
merr6267 is offline   Reply With Quote
Old August 17th, 2008, 07:30 PM   #11
mudd_jumper
mudd_jumper's Avatar
OH sweet !!!! got to love red neck engineering!
Old August 17th, 2008, 07:40 PM   #12
kickstand
circling the drain
kickstand's Avatar
That was standard fair for straight axle chevies for a long time, if installed correctly its no big deal.
Page generated in 0.24520 seconds with 59 queries
