Body mounts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2008, 05:55 PM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default Body mounts
well i looked and one or two of my body mounts are rusting out. now to avoid my body falling in and caving id like to make a new one, or get a new one. questions being how do i make one? my guess is 1/4" plate cut into the shape and welded but i would like to know whats best. and if they ARE available; where could i purchase one?
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old August 11th, 2008, 06:04 PM   #2
xj97sport
atv rider
xj97sport's Avatar
at the junk yard ... with a saw lol
preferably a circular saw
Old August 11th, 2008, 09:25 PM   #3
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
i would just make them like you said would be easier and cheaper
Bronco Ollie is offline   Reply With Quote
Old August 12th, 2008, 08:04 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
body mounts on what?
most aren't expensive, i replaced cab mounts on two different ranger i owned and the piece was only like $25
just cut the rivits and bolt back on
Old August 12th, 2008, 05:19 PM   #5
why are you in ford tech?
why would i want a used rusty one?
what is your unhealthy obsession with circular saws?
id probably use a 4-1/2" angle grinder with a cutting disc
Old August 12th, 2008, 05:23 PM   #6
for my 88 bronco, i know how to install them, and stuff but i was looking for some leads on some NEW ones (due to strength issues)
Old August 12th, 2008, 05:29 PM   #7
xj97sport
atv rider
xj97sport's Avatar
cause i wanna see what ur cobblin up on
it might not be as rusty as urs
i just wanna see ya use on on metal to see how it works out for ya
Old August 12th, 2008, 08:11 PM   #8
cause i wanna see what ur cobblin up on GAY stalker.
it might not be as rusty as urs but still rusty
i just wanna see ya use on on metal to see how it works out for yaGayer.
there.
Old August 13th, 2008, 10:28 AM   #9
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
JBG should have some new ones.
Bronco351 is offline   Reply With Quote
Old August 15th, 2008, 06:07 PM   #10
i looked and seen everything BUT those lol
Old August 15th, 2008, 08:59 PM   #11
blownexploder94
Todd
blownexploder94's Avatar
did you try jeffs bronco graveyard...... if its just the top of the mount like where the hole is in the top, if its rusting out getting larger you could weld a 1/4 in plate to the top of it and cut your own hole.. my brother has a 78 bronco he is doing a frame off resto and the rest of his mount was solid but just the top was letting the mount fall threw so he welded a plate to it to the same size can;t even tell it was touched now... he has gotten every single body part frame and axle parts from jeff's most everything is in stock to
Old August 15th, 2008, 09:00 PM   #12
blownexploder94
Todd
they have a hole kit for the bushing its self to rubbers and polyurethane
Page generated in 0.31961 seconds with 59 queries
