Hartland '89 Bronco II - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2009, 12:01 AM   #141
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
did you win that match?
Bronco Ollie is offline   Reply With Quote
Old January 14th, 2009, 12:13 AM   #142
88mudder
In the band!
how did them coil spacers work out? I had a homebrew set just like that and i loved em.
Old January 14th, 2009, 01:06 PM   #143
Jdc215
Jdc215's Avatar
that is my buddy he thought it would be funny to post a picture on my build thread, i left it logged on while i went to the hardware store.
i havent been able to get to a lathe to finish the spacers yet
Jdc215 is offline   Reply With Quote
Old January 15th, 2009, 07:28 PM   #144
Jdc215
Jdc215's Avatar
finally getting my truck back tomorrow. they determined that the premature failure wasnt my fault. apparently it was a defective part involved in the rebuild that didnt allow the trans fluid to lubercate the moving parts, they might be feeding me a line on this one but it dosnt matter to me because they are fixing it on warranty. unfortunatly it hasnt been pushed through too fast and i havent driven it in over a month and only seen it once since. really anxious to get it back,
Old February 22nd, 2009, 09:16 PM   #145
Jdc215
Jdc215's Avatar
got a job last week going to start making some money. im looking to gete a brushguard or possibally build a replacement bumper, and get the LS unit working propperly. i think im going to put more emoney into my three wheeler for several reasons.
1. its Cheaper to run (gas) and fix
2. its dosnt get stuck as easily and easier to recover when stuck
3. if i get a trailer for it i can use eit alot more often
4. Its faster than the bronco
5. Finally its built and designed to take the abuse i put on things
Old March 12th, 2009, 10:53 PM   #146
Jdc215
Jdc215's Avatar
i had the diff serviced, about a $50 job, for a customer. i found out i have a cheesy plastic diff cover and i cant find a decent one anywhere. i also put on a neew fuel pressure regulator wich helped out alot, but i also found out the trans shop ruined my one eand only O2 sensor so i have to replace that and put a new muffler on it before it will be running right again.
i know i make alot of lists but my currenet priorities include
oil change
O2 Sensor
Coil spacers
bumper or guard
Lights-only two
fix limited slip unit
shocks
Old March 13th, 2009, 09:12 AM   #147
deathbypsi
Brian R.
deathbypsi's Avatar
Keep at it man,we need more of these things out there!
Old March 13th, 2009, 09:26 PM   #148
Jdc215
Jdc215's Avatar
the oil change and the o2 sensor are egoing on this pay check and i have the coil spacers but i need to get them fine tunned and mounted.
i was hopping to buy that axle from you some time though
i am tennitavely planning on going to the mounds with LOTUSEXIUGE next weekend, anybody intrested in going all day is welcome, we might bring atvs too depending on wethor i can get my trailer lights hooked up or not
Old March 14th, 2009, 12:34 AM   #149
deathbypsi
Brian R.
deathbypsi's Avatar
I think the Mounds is closed to trucks already.
Old March 14th, 2009, 09:12 PM   #150
Jdc215
Jdc215's Avatar
i forgot about the down time, well i guess well have to reschedule then.
Old March 26th, 2009, 08:10 PM   #151
Jdc215
Jdc215's Avatar
I started a brakes and a auto Heating and cooling class at Oakland CC. so i bought pads to do my front brakes. after tearing it apart i found that they wont let you do your brakes without rebuilding or replacing either the caliper or the cylinder. so i ended up buying two rebuild kits. then i found out that my rotors were so warped that to get them straight took them out of spec, so... i ended up buying two rotors. in all i spent $125 on brakes.
ill be doing my rears next, but i have to replace both axle seals, both cylinders, all the hardware and the shoes. i hope the drums aren't scored, and i hope they are in spec. so i don't have to replace them too. that wont be cheap. i still need to replace my coil and O2 sensor too.
on the up side i bought a brush guard from 88mudder and i have all the new bolts and some lights to mount on it. it will also give me a place to mount a CB antenna. i plan on having that mounted up in the next few days. then ill do the coil spacers at school, then ill work on the CB and getting that rear axle from DeathByPSI.
Old March 26th, 2009, 08:14 PM   #152
deathbypsi
Brian R.
deathbypsi's Avatar
Old March 26th, 2009, 08:20 PM   #153
88mudder
In the band!
if ya end up needing new drums stop by my house, ive got like 2 sets and dont forget your Chilton
Old March 26th, 2009, 09:14 PM   #154
Jdc215
Jdc215's Avatar
thanks will do
Old March 28th, 2009, 08:32 PM   #155
Jdc215
Jdc215's Avatar
so my buddy's dad owns some property outside of town and on the edge three pieces of land come together. in that area there is a swamp with a small off road track going around the swamp and trough in the dry areas. we intended to go to another place but we weren't able to get a hold of the land owner. so this track is primarily for dirt bikes and four wheelers, but since his dad has an equal share in the track we thought it would be ok to go there with out trucks, it was just the two of us. so we asked one of the other partial owners, who has let us go back there before, and he again cleared us. we didn't contact the other guy though because we didn't think he was home. so we go through this track about three times and out of no where this guy comes barreling up the track in his brand new f-250. he we all get out of our trucks and he starts yelling asking who we think we are. my buddy says that his dad owns one third of the track and that the other land owner had cleared us and we weren't aware that he was home. he being in a state of irate anger pulls a gun out of his pocket and while pointing it at us tells us that he brought it with him to shoot out all out tires. both of us were a little alarmed that he had a gun but our first reaction was to identify it, it was a foreign pos. while holding us at gun point he informed us that he was liable for anything that happened on that track. the first thing i thought: isn't my buddies dad liable every time you ride your dirt bike on his part of the track. in the end he put the gun away, we apoligised several times and left to go talk to third owner.
what do you guys think?
was i in the wrong or was this guy with the gun in the wrong?
Old March 29th, 2009, 08:36 AM   #156
deathbypsi
Brian R.
deathbypsi's Avatar
Ok pullin a gun on some people driving on a off road track is a little over the top if your askin me! Do it in somebodies front yard then OK I can see that!
Sounds like a simple and honest lack of communication. Honestly I prolly would have kicked the guys ass after he put it away for just reacting that over the top, but I have a bad case of "big guy" syndrome.
Old April 1st, 2009, 08:47 AM   #157
Jdc215
Jdc215's Avatar
well i completely re did the front brakes as part of my class and spent alot more than expected but oh well, i guess they'r good for a while. i was also to get everythnig together to do the brush guard an lights should be done soon.
Old April 2nd, 2009, 09:26 PM   #158
Jdc215
Jdc215's Avatar
i'm not too happy with how th brush guard fits, its no ones fault, and i'm having a little difficulty figuring out how to mount it in a sturdy fashion. i met a new friend recently and i think i might try to build a bumper for the front with his help, and sell the guard. that way i can fit my 6" kc hilites on there instead of the off-brand lights i would have has to use to fit the guard. i think ill be able to fix the crack in the frame soon too.
Old April 8th, 2009, 01:33 PM   #159
Jdc215
Jdc215's Avatar
yesterday i pulled the coils off to find that the spacers i built need to be re-cut, since the hole isnt big enough. i got them cut bigger ans should have them on tomorrow. ill post pictures if it makes much of a difference.
Old April 17th, 2009, 10:57 PM   #160
Jt91bronco
Jt91bronco's Avatar
i got the coil spacers cut right but i think im going to hold off. i put them in and they did a lot more than i thought so nows not the right time. one of my spring pockets gave out the other day though. i have it parked for now. trying to figure out the new brackets, shackles and mounting bolts. now i got most of the old list done so now:
replace rear spring hardware
patch frame crack
rewire tail lights
Jt91bronco is offline   Reply With Quote
Page generated in 0.57386 seconds with 84 queries
