Hartland '89 Bronco II - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2008, 11:35 PM   #121
Jdc215
Jdc215's Avatar
I have been having some problems with my headlights lately. after about a through hour i figure the problem is that the switch for the headlighs went bad. i was wondering if anyone else has had problems with one of them before. i am going to stop by the junk yard and pick one up tomorrow, hopefully that fixes it.
Jdc215 is offline   Reply With Quote
Old November 8th, 2008, 11:12 AM   #122
Jdc215
Jdc215's Avatar
i replaced the headlight switch and they work now. last night i went out with some friends and had a blast tearing up some trails.
Thanks Dave.
Old November 17th, 2008, 09:51 PM   #123
Jdc215
Jdc215's Avatar
didn't notice untill the 10th that i smashed up my bumper a little when i nosed into that hole last time things are bent but besides the bumper everything else is fine. i should still be able to mount that brush guard no problem though. ill be going home over thanksgiving so ill mount that guard sometime before christmas
Old December 1st, 2008, 04:01 PM   #124
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
if you still want me dana 35 it's yours ill even sell you the 4" lift stuff with it if you want i tried sending you a pm but you haven't got back to me so let me know if you still want it we can work out a price for all of it
Bronco Ollie is offline   Reply With Quote
Old December 1st, 2008, 04:04 PM   #125
88mudder
In the band!
hey JDC, when are you coming out to get the brush guard?
Old December 2nd, 2008, 06:42 PM   #126
Jdc215
Jdc215's Avatar
i was out for thanks giving but i didn't have a car, my parents picked me up, and it was only three days. ill try real hard to drive MY truck home this time, i cant make it work unless i drive it home. ill do the best i can, ill be back on the 19th.
Old December 13th, 2008, 10:52 PM   #127
Jdc215
Jdc215's Avatar
i built some coil spacers of approximately 1" out of some hot rolled 3.25" steel. i think both are actually around 900 thousandths but close enough that it wont make a difference when they are mounted. should help it sit level. I was thinking of using hockey pucks a few months ago but i heard they can brake i don think that will be a problem with steel.
Name:	Coil Spacers 1''.jpg
Old December 25th, 2008, 08:03 PM   #128
Jdc215
Jdc215's Avatar
trans getting rebuilt under warranty. i dont know what the problem is. i dont beat it up and its only been 3 months/2,000 miles since they first rebuilt it. honestly i beat on the factory trans alot harder and it had over 160,000 miles on it? i havnt done anything abnormal and seriously took it easy since the last rebuild.
Old December 25th, 2008, 08:17 PM   #129
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
hmm, well good thing it had a warranty, paying for 2 trans rebuild in a year would suck.
Bronco351 is offline   Reply With Quote
Old December 25th, 2008, 08:38 PM   #130
88mudder
In the band!
still have the brush guard, are u home yet?
Old December 25th, 2008, 08:41 PM   #131
88mudder
In the band!
nice looking spacers, ive had a homebrew set like that. MAKE sure you bore a shallow 1 1/4" hole on one side of them or else the spacer cannot sit flat on the axle beam itself.
Old December 26th, 2008, 03:41 PM   #132
Jdc215
Jdc215's Avatar
i didnt know that but i can get to a lathe some time to finish it.
Old December 26th, 2008, 03:52 PM   #133
Jdc215
Jdc215's Avatar
thanks i didnt know it would also need to counter bore the spacers. you know how big the studs are i cut the holes at 3/4 because i figured too big was better than too small in this case.
Old December 26th, 2008, 10:42 PM   #134
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
correct but there is also a nut on that stud u forgot to account for..
Old December 26th, 2008, 10:46 PM   #135
88mudder
In the band!
3/4 should be enough clearance
i KNOW d35 studs are shorter than d28 studs...so 1" spacer may need stud extenders of you want the nut to fit on all the way since you run the d35. You will only know by trying it out, ive never done it on a 35. I think 94rangeron35's is right, i know he ran the d35 in his truck before.
Old January 2nd, 2009, 06:14 PM   #136
Jdc215
Jdc215's Avatar
i need to fix that i actually have a Dana 28
Old January 9th, 2009, 04:55 PM   #137
Jdc215
Jdc215's Avatar
went into the shop today. they still haven't fixed the transmission, its been three weeks, but they did tell me what was wrong. and that it wasn't my fault. apparently he rebuilt it and one of the parts was defective thus preventing the trans fluid from lubricating the moving parts. they said they are now trying to get the parts from their supplier so they can get it fixed for me.
Old January 9th, 2009, 04:57 PM   #138
88mudder
In the band!
Interested in a dana35 with 3.73 gears?
Old January 9th, 2009, 06:28 PM   #139
Jdc215
Jdc215's Avatar
once i get a job. how much?
Old January 13th, 2009, 10:57 PM   #140
Jdc215
Jdc215's Avatar
Pic
Page generated in 0.48116 seconds with 84 queries
