Hartland '89 Bronco II - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2008, 06:57 PM   #101
Jdc215
Jdc215's Avatar
Well today i was towing a friend and needed more torqueso i put it in low range. when i was done I couldn't get the auto hubs to unlock. Long story short i broke a drivers side axle shaft. If any body has any Dana 35 TTB axle shafts for sale i would be in terested. everyone says that the "flimsy" auto hubs will break but aperently in this cas the staft broke. both shafts need replacing as both yokes and the u-jount caps are broken. I hear it is alot of work to replace the shaft any advice would be welcome i want to get it bone before things get cold.
Jdc215 is offline   Reply With Quote
Old October 14th, 2008, 07:03 PM   #102
88mudder
In the band!
PM HazardousRanger, he should still have a set of spare shafts that i sold to him.
Replacing the shafts are easy, just pull the hub off and remove the C-ring on the end of the shaft and it will slide out. This makes for a good time to repack wheel bearings too. The bearings tend to sieze to the spindle , i always grease mine up good.
Old October 14th, 2008, 07:11 PM   #103
Replacing the shafts are easy, just pull the hub off and remove the C-ring on the end of the shaft and remove the lock nut, take the caliper off. Be careful of the little keyway that locks the nut and it will slide out. Unscrew nut and remove rotor. Then their is 5 nuts (15mm i think) remove those then you have to get the spindle hub off and THEN you can slide the shaft out. This makes for a good time to repack wheel bearings too. The bearings tend to sieze to the spindle , i always grease mine up good.
Added a few steps you forgot
Also in order to "unlock" the auto Hubs, you need to go in reverse in 2wd. Cintrifical force is what locks the hubs in forward motion.
Old October 14th, 2008, 07:14 PM   #104
88mudder
In the band!
Also in order to "unlock" the auto Hubs, you need to go in reverse. Cintrifical force is what locks the hubs in forward motion.
thx..i havent removed shafts in along time, i remember just a bit.
Old October 14th, 2008, 07:29 PM   #105
Jdc215
Jdc215's Avatar
I went as far as i could in reverse (2wd), but there wasn't much room. like i said i tried to avoud this problem but shit happens, the shaft is broke and in the future i will have manual hubs so i dont have this problem again.
Old October 16th, 2008, 12:42 AM   #106
Jdc215
Jdc215's Avatar
Fixed the axle and replaced the auto hubs with manuals. today i went over to daves house and he helped me fix the axle shaft and replace the hubs. i was glad he knew what he was doing. i have never had the chance to pull apart the front axle but i am sure with enough time i could have figured it out, but he alsl had the right tools for the job which made things alot easier too. Thanks for all the help dave.
unfortunatly in the process i found out i have a dana 28. that will change once i have the money.
Old October 16th, 2008, 01:23 AM   #107
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
that sucks that you found out that you have the dana 28 but good to hear you got the shaft replaced
Bronco Ollie is offline   Reply With Quote
Old October 16th, 2008, 06:30 PM   #108
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
Dana 28 could survive as long as you go easy on it. You could probably get a dana 35 fairly cheap. I have seen them for sale in the past on this board for <$100.
Bronco351 is offline   Reply With Quote
Old October 16th, 2008, 07:12 PM   #109
i have made the D28 survive on 32x11.50 MTs and LOTS of abuse
94rangeron35s really 37's (that never gets old) hes good people
Old October 16th, 2008, 07:15 PM   #110
88mudder
In the band!
x2 i have 33's and the d28 and it has lasted. As long as you dont hit the gas and smack down its all good..
Old October 16th, 2008, 07:17 PM   #111
Bronco351
Powered by Ford
Bronco351's Avatar
mine survived stock tires and mud puddles on the side of the road, but some of those puddles were pretty wicked
Old October 16th, 2008, 07:19 PM   #112
88mudder
In the band!
ive blown ALL the ujoints on it but the shafts dont snap. The Warn hubs are nice on the d28
Old October 16th, 2008, 07:22 PM   #113
Bronco351
Powered by Ford
Bronco351's Avatar
i had the warns too, i dont think i broke any u joints, but i pretty much ruined the all the ball joints.
Old October 16th, 2008, 07:40 PM   #114
Jdc215
Jdc215's Avatar
i like the warn hubs. arent the facotry dana 35 hubs made by warn too. it will have to last till this summer most likely. i dont think i will have the extra money till then. Most importantly the 4x4 has been restored. which means i should be set for this winter so long as i dont break somthing else.
Old October 16th, 2008, 09:19 PM   #115
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
not a problem im glad i could help you out, and like i told you last night i wasnt going to leave you hangin with a bad wheel bearing and spindle i had the parts.
Old October 17th, 2008, 12:35 AM   #116
Bronco Ollie
the dana 28 can handle 38's but axle shafts break easy i know someone who did it
Old October 17th, 2008, 09:35 AM   #117
dana 28 can't handle 38's lol
Old October 17th, 2008, 11:02 AM   #118
Bronco Ollie
someone did it for like a month but they kept break axle shafts i would never do it but to each there own
Old October 17th, 2008, 11:54 AM   #119
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Dana 35 can handle 38's
Old October 17th, 2008, 04:51 PM   #120
Jdc215
Jdc215's Avatar
well i dont plan on running anything bigger than 33s so long as it is my dd. i thi8nk it will be my dd for at least another year and a half.
Page generated in 0.45687 seconds with 84 queries
