Hartland '89 Bronco II - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2008, 04:19 PM   #81
i do not have a trac bar on the front of mine, however i should put one on it. I still get alot of side to side movement in the axle while turning. But i do not drive it on the street so its fine as is
Old October 12th, 2008, 04:30 PM   #82
Jdc215
Jdc215's Avatar
why isnt there one in the rear?
Jdc215 is offline   Reply With Quote
Old October 12th, 2008, 05:03 PM   #83
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
a trac bar??
your rear axle doesn't have steering components so the leaf springs hold it in place just fine.
Bronco351 is offline   Reply With Quote
Old October 12th, 2008, 07:48 PM   #84
Jdc215
Jdc215's Avatar
i see. so if you had 4wheel steering, which i have seen on some crawler/buggies, is a trac bar necessary in the rear, or is it not that big of a deal?
Old October 12th, 2008, 07:58 PM   #85
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
my b2 came stock with a dana 35 also and i got a 90
Bronco Ollie is offline   Reply With Quote
Old October 12th, 2008, 08:14 PM   #86
Bronco351
Powered by Ford
Bronco351's Avatar
i am going out on a limb here and i'm gonna say yes. Physics, equal and opposite reaction, the "pull" on the axle when you steer, etc... trac bar keeps it in place. so if you have that pull on the rear axle as well, i'm gonna say you need a trac bar to hold it as well. Then again though, depending on how it's all set up, you may not need it.
alot of physics and it's the weekend and i'm being lazy.
Old October 12th, 2008, 08:46 PM   #87
Jdc215
Jdc215's Avatar
not that it will effect me any time soon but i was curious.
On another note, I am still looking for a grill guard so i have a place to mount my lights. if you've got one let me know.
Old October 12th, 2008, 08:49 PM   #88
Bronco Ollie
i know 88mudder has one but i dunno if he is selling it cause i sold it to him awhile back
Old October 12th, 2008, 08:51 PM   #89
88mudder
In the band!
still got it, i never mounted it. Its for sale right now!
Old October 13th, 2008, 06:12 PM   #90
Jdc215
Jdc215's Avatar
today i started working on how to mount those towhooks. i was in machining class and decided the only way to get enough of the right stuff out of the scrap bin was to use 8, 4 each side, .25x1.5x5 inch pieces of Metal to drop the Hooks about .5" below the bumper. i had to cut all the pieces with a hack saw because people were using the band saw. i got all pieces cut and began filing to remove the burrs and help things look a little better. then i lined them up the way i wanted them and with the hook and clamped them togethen and began using the holes in the hook to start the holes. i then rotated the hook out of the way and finished drilling the hole. next i put a bolt in the completed hole, alligned the metal and began drilling then removed the hook. i did the same on the other side and to mount i used 2 existing holes. one had to be elongated. ill post pictures later. i still want to weld the plates together and paint them to reduce corosion.
Old October 13th, 2008, 06:17 PM   #91
Bronco351
Powered by Ford
Bronco351's Avatar
Make double sure that you get those tow hooks on right, it would be terrible to have them fly off during recovery. I'm sure you already know though but just to overstate the point.
You may want to use something like POR15 for your plates, should keep them from rusting better than just ordinary paint.
Old October 13th, 2008, 06:34 PM   #92
Jdc215
Jdc215's Avatar
what do you mean, i would think 1/2 inch grade 8 bolts shoud be able to hold the psacers, tow hook and frame together. planned on reafing them down as hard as i can. i dont know how much torque that is but with the lock washers it should be enough to hold and not vibrate loose.
what exactly is this POR15 stuff?
i was thinking of sand blasting everything an using some autozone rattlecan bed liner stuff $10 a can. Has anyone ever tried this stuff. i was thinking of doning the same thing to the brush guard when i get it. just wondering if it holds up.
i had also considered some of that ruberized undercoating but again i dont know how dureable it is.
any ideas would be aprecieated.
Old October 13th, 2008, 06:46 PM   #93
Bronco351
Powered by Ford
Bronco351's Avatar
yeah, those bolts will hold.
POR-15 is rustproofing paint essentially
http://www.por15.com/
The rattlecan bedliner stuff will come off and rather easily too. after a while it just flakes off.
Old October 13th, 2008, 06:49 PM   #94
Jdc215
Jdc215's Avatar
so how does this por15 hold up against chipping?
Old October 13th, 2008, 06:52 PM   #95
Bronco351
Powered by Ford
Bronco351's Avatar
Yes.
and to cracking and peeling as well.
Old October 13th, 2008, 07:01 PM   #96
Jdc215
Jdc215's Avatar
where do you get it and how much is it and do you use any of the prep chemicals they sell?
Old October 13th, 2008, 07:05 PM   #97
Bronco351
Powered by Ford
Bronco351's Avatar
You can get it from National Parts Depot, i think autozone and murrays may sell it, and probably at a paint supply store. It does carry a hefty price tag but you wont be repainting anytime soon. You wouldn want to use the metal ready stuff, that will help it stick to the metal real good. You will probably end up totalling somewhere around $40 or so being that you wont need alot of it.
Old October 13th, 2008, 07:10 PM   #98
Jdc215
Jdc215's Avatar
i would or would not want to use metal ready?
you typed wouldn
Old October 13th, 2008, 07:11 PM   #99
Bronco351
Powered by Ford
Bronco351's Avatar
would
sorry, i suck at typing
Old October 13th, 2008, 07:28 PM   #100
Jdc215
Jdc215's Avatar
thanks. ill see where i can find it. i think ill just out them on for now and take them off when i do the brush guard
Page generated in 0.29555 seconds with 84 queries
