1995 C6 trans problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2008, 11:18 PM   #1
offroad86b2
offroad86b2's Avatar
Send a message via AIM to offroad86b2
Default 1995 C6 trans problems
A friend of mine bought two 1995 ford E250 4x2 vans one has a bad engine the other has a bad trans.So we took the two and made one.the problem we are having is the trans its a C6 now when its in park it seems to be in drive too,when its in reverse it trys to go but seems like its in drive still...neutral is drive and drive is drive.you go down the road it shifts great through the gears.It just seems like its always stuck in drive..
I never messed with the internal linkage or know much about auto tranys,so if anyone has any ideas i would appreciate.
Thanks
offroad86b2 is offline   Reply With Quote
Old August 11th, 2008, 08:33 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
pull the pan and make sure the manual linkage is hooked to the manual valve.
Old August 13th, 2008, 07:42 AM   #3
offroad86b2
i pulled it and its all hooked up so,i would have to say maybe a sticky valve in the valve body!! i dont know,the trans did sit for few years.
Old August 13th, 2008, 11:16 AM   #4
Tom
Because racecar
Tom's Avatar
Sounds like the forward clutches are smoked and locked on.... Just a possibility.
Page generated in 0.14715 seconds with 35 queries
